LED low battery warning on arducopter
Hi all, On popular request, here's a short tutorial on how to make a low battery warning on my hexa with blinking leds, as you can see at the end of the following video :
EDIT : The software changes in this blog are now outdated and not necessary anymore.  For the new software see my new blog with much more possibilities (without using the relay) : U4eake's showleds, arming and low battery warning leds
Furthermore I'll use this as a reminder on what to change in my code when new versions come out :-)
First I'll give proper credit where credit is due, this code was originally written by Bill Sanford and posted on rcgroups here : Bill Sanfords running lights.  They are originally intended to be run with a brushed esc, so they can pulsate.
I never found an explanation on the 'attraction mode' leds on standard arducopters, so I modified Bill's code it a little and used the onboard relay to drive my hobbyking 12V leds :  http://www.hobbyking.com/hobbyking/store/__8941__Turnigy_High_Densi...
I have a lot of them, so they draw much more current then the outputs of the APM can provide, but the relay has no problem with it.
General principle :
I have the leds setup as follows : on arming motors, the leds go on, indicating the copter is armed.  On disarming they go out.
When battery voltage reaches 10.6V the leds start blinking slowly (2 Hz).  From experimenting I know that I now have about 1 min of flighttime left with my battery.  You may need to experiment yourself to find out how much you have left.
When voltage goes down to 9.9V, it's really time to land (about 15s left) and the leds start blinking rapidly (5hz).  This is also the time when the copter will go into RTL, unless you modify the code (will get to that later on, see software, point 3. event.pde)
Hardware :
First the hardware.  I soldered a 3S balancing connector to the relay ports of the IMU as shown in the pictures. Yellow wire goes to pin AN0 on the imu.  Red wire goed to middle pin of relay.
PAY ATTENTION : on the 3S connector, swap the black and yellow wires if you use standard 3S balancing connectors !!!  Standard 3S balancing connectors have the black wire on the rightside end in the picture below.  On the imu however, the third pin is ground and the rightmost pin is AN0 which should be connected to +12V.  So swap the wires if you're using a standard 3S balancing connector or you'll invert polarity and damage your board !
Then on the other side of the imu, solder the ground pin together with relay pin 0 with a solder bridge.  Also solder a short wire, connecting the pin AN0 (yellow wire) to the right side relay pin (pin 1).
Now connect Yellow to battery +12V and black to battery minus.  Connect red to leds+ en blue to leds-.  All leds should be connected in parallel to the red and blue wire.  Don't overdo it though, the relay must be able to handle the amps.  60 hobbyking leds (1m) is still fine.  If you want more, check ampdraw en relay specifications.
With relay in pos 0, the red wire (led+) is connected to ground, so leds are off.
With relay in pos 1, the red wire (led+) gets fed +12V comming from Yellow wire at AN0.
Furthermore AN0 is constantly connected to +12V from battery so it can monitor battery voltage.
Your hardware changes are now done.
DISCLAIMER : I assume if you do this that you have sufficient knowledge about soldering and electronics.  Even though I tried to explain as best as I could, I take NO responsability if you destroy your board doing this.  Do this at your own risk !
Software : These changes are no longer valid, see my new blog mentioned above for recent code !
You'll need to make the following modifications the the firmware and then compile and upload with arduino.
1. In ArduCopterMega.pde
Find the medium_loop() function and in it find case 4.  There is a call to the read_battery() function there.
Insert a call to handle_relay_lights() right after the read_battery() call.  See red text below.
// This case controls the slow loop
case 4:
  loop_step = 5;
  medium_loopCounter = 0;
  delta_ms_medium_loop = millis() - medium_loopTimer;
  medium_loopTimer     = millis();
  if (g.battery_monitoring != 0)
  read_battery();
handle_relay_lights();
  ArduCopterMega.pde is now ready.  Don't forget to save it !
2. APM_config.h
Add the following code :
#ifndef BATTERY_EVENT
# define BATTERY_EVENT ENABLED
#endif
#ifndef LOW_VOLTAGE
# define LOW_VOLTAGE 9.9
#endif
#ifndef MID_VOLTAGE
# define MID_VOLTAGE 10.6
#endif
#ifndef VOLT_DIV_RATIO
# define VOLT_DIV_RATIO 3.33
#endif
#ifndef INPUT_VOLTAGE
# define INPUT_VOLTAGE 5.26
#endif
// global variables for motor leds and battery monitoring through onboard relay
int rl_state   = 0 ;     // this global variable is used to save the on/off state of the relay
int rl_counter = 0 ;    // this global variable is used for the flash rate timer
I know the variables should probably be defined in parameters.h but upto now I've been too lazy to do so...  If you want to, pls do so, but bear in mind that it's an extra file to modify each time a new firmware comes out.
  That concludes the APM_config.h modifications. MID_VOLTAGE is when the lights start flashing slowly, LOW_VOLTAGE is when they flash rapidly and when copter goes into RTL.
You may have to experiment a little to find the right values for you.  See also the wiki about battery monitoring.
3. Events.pde As of version 2.0.38 this step is already implemented in Events.pde, no need to change it.
Since I now have leds to warn me when battery gets low, I don't want the copter to unexpectedly go into RTL cause my leds have been blinking and I didn't land in time.  One time when I was testing this, hoovering low with blinking lights, my copter suddenly took of and flew into the hedge.  Luckily I wasn't in between.
So I only want the copter to go into RTL when he's flying on an  automatic mode (auto, loiter), not when I'm in control.
Find the line void low_battery_event(void) in the event.pde file.
Change the whole function to look like this (red text changed) :
gcs.send_text_P(SEVERITY_HIGH,PSTR("Low Battery!"));
if (control_mode > ALT_HOLD) { set_mode(RTL); }
I am thinking hard if it wouldn't be better (if possible) to change it into set_mode(Land); to have the copter land on an empty battery instead of attempting to get home with no juice left (which will probably end in disaster if the copter is more then 15sec away from home)
4. RunningLights.pde
Add the file RunningLights.pde to the directory where ArduCopterMega.pde is located.  This is a new file to add.   You can download it below.
RunningLights.pde
That's it !!!  Compile and upload with arduino, enable battery monitoring to battery volts in setup (type setup in CLI and then battery 3) or choose battery volts in mission planner -> hardware setup -> monitor.
Enjoy and feel free to ask questions !
Tags: arducopter, battery, leds, low, warning
Distributor
Comment by Dany Thivierge on July 20, 2011 at 8:02pm
Nice!
thanks for the detail explanation.  Also I see that you solder all 4 resistor for bat. monitor.  is it because you are running 4S? I always wonder if I can put all 4 for a 3S lipo...
Other question,
Do you know how much current the led strips draw? how much does it affect the flying time?
I have all the parts to do it... now I think I will make it happen! this will replace my motor mount led... or I may leave both... :)
Thanks again.
Comment by John Church on July 20, 2011 at 8:21pm
u4eake, very nice and comprehensive. The following might not be a bad mod no matter if a user is utilizing LEDs or not, as I've experienced the same condition as you while testing battery monitoring.
Dany, you can solder in all 4 resistors if you like. If nothing's hooked up to them and ground to complete the circuit, they won't do anything anyway.
Comment by Dani Saez on July 20, 2011 at 11:31pm
Great job u4eake!
I myself was searching in the Pirates thread for the info posted by Bill, to try to get it to work with the AC2! ;-)
I'll try it asap! Thanks!
btw, you should pm Jason and integrate this mod in the AC2 code, so we don't have to keep on modifying code with every release.
Dani
Comment by Jason Wise on July 21, 2011 at 6:02am
Many thanks for your great work! cant wait to test it out!
Comment by Dani Saez on July 21, 2011 at 9:42am
Hi u4eake,
I believe you must enclose the call to handle_realy_lights in a #define, otherwise, if you disable the BATTERY_EVENT you'll get the error:
ArducopterMega.cpp.o: In function `medium_loop':
C:\Temp\build7557884362017530897.tmp/ArducopterMega.cpp:1070: undefined reference to `handle_relay_lights()'
so the call should be:
if (g.battery_monitoring != 0){
  read_battery();
  #if BATTERY_EVENT == ENABLED
  #endif
geting ready for testing....
Dani
Comment by u4eake on July 21, 2011 at 12:11pm
Thanks for the nice comments guys !
Good catch Dani !  I never tested setting BATTERY_EVENT to disabled.
If I remember correctly the led strip of 1m (60 leds) drew 400mA.  My hexa in hoover draws 20A, so that would be 2% of flighttime I loose due to the leds... That means on a flighttime of 10min you loose 12sec
That's the theory.  In the real world I gained flighttime, cause now I can fly with confidence until my battery is empty, while before I used a timer and stayed on the safe side of my flighttime.
Comment by u4eake on July 21, 2011 at 12:23pm
Forgot to include a video on the leds, but in the following video at the end, you can briefly see the leds start to blink as my battery gets empty :
http://www.youtube.com/watch?v=piBedxcT-WI
Comment by roger on July 27, 2011 at 10:41pm
Dani, Jason and John,
Would you care sharing your experience on integrating u4eake code to your ardu's? how did the flight go and did it enhance or degrade your flight time? ... thanks.
Comment by Dani Saez on July 30, 2011 at 10:37am
Here's my first "report":
I folowed all the steps, compiled the code soldered pins, then I took the connector from a battery, ok.
Getting ready to plug, bla, bla bla, then NOTHING. I think I've blown up something...
It was completely my fault, as I had the laptop in another room, I wrote down in a paper the wire colors and where went each one of them.
What I did not check, were the colors on my connector!!! mine had the yellow and black swapped, so I connected the power from the batteries inverted!!! :-(
Had I printed the pics or taken the laptop to the other room, this would not have happened...
Damages detected so far:
 - Ubec is gone
 - Receiver is not turnong on anymore
 - APM is not booting, first tests shows that using the USB cable the CLI connects... have to do further testing..
So, RE-CHECK your connections and DO NOT TRUST THE WIRE COLORS!!!
While I do more testing trying to recover the APM, I've ordered a new pack...
Dani
Comment by u4eake on July 30, 2011 at 12:49pm
Damn, now I remember... I did swap the yellow and black wire on my balancing connector, so that the black wire would be ground. Did this to avoid any confusion comming from a yellow wire being ground and a black one 12V. Black should always be ground.
Seems that what I tried to avoid, still happened just because I tried to avoid it. Feel really bad about this :( I can't change the blog anymore apparentely, if I could I would write in in red : SWAP YELLOW AND BLACK WIRE ON THE CONNECTOR.
Comment
