I've been working on-and-off on a cross-platform GUI for mavproxy, which I've been calling "mavgui". it's written in QT, and so will run natively anywhere where Qt will ( Mac, Android, Windows, etc ) ... and I've just started to add support in it for a "browser" window ( http://diydrones.com/profiles/blogs/browser-based-map-module-for-ma...) , that app would fill perfectly!
I think I'm going to integrate these three into a GCS solution. :-)
My Work-in-Progress QT based GUI is here: https://github.com/davidbuzz/MAVProxy/tree/master/mavgui
The great thing about the mavgui I'm working on is that it's GUI is put together with a tool called "Qt Designer", and is 100% python, so it's trivial to change/tweak the layout for different use-cases like phone etc. The Designer outputs XML, and the rest of the application is 100% python. Here's a quick look at the XML loaded into the "Designer"....
It's not really "one giant GCS" in any sense of the word.. for a start it uses mavproxy and mavproxy modules for most of the underlying comms stuff, and everything else is just easy-to-read python. :-) maybe we should start a new thread for mavgui. ?
There are a couple of parts to my experiment:
(1) completely separate the GUI from mavproxy, so if the GUI crashes, the mavproxy does not.
(2) integrate with a standard mavproxy, with no changes required other than adding a "module".
"netconsole" - an underlying part of mavgui
Sending commands from the GUI "TO* mavproxy ( and hence your UAV) occurs over a tcp/ip connection to the MAV> console, by using a new mavproxy module called "netconsole". As a bonus, you can now also use netcat, telnet, or any other language to instruct MAVProxy. :-)
https://github.com/davidbuzz/MAVProxy/blob/master/modules/netconsol...
want to put your UAV into AUTO mode from the command line? try this: echo "AUTO" | nc localhost 45678
want to communicate with a Mavproxy on another machine on the LAN? try this: telnet otherhostip 45678 ( and you'll see a MAV> prompt, just like it was local!
using pymavlink...... another undelying part.....
There's only so much you can do with a tool like "netconsole", as I cant ( yet ) use it to communicate information about the current state of the UAV.... so I've additionally additionally got mavproxy sending a stream of UDP packets ( --out=127.0.0.1:xxxx ) to mavgui, and using pymavlink I am displaying the latest HUD style information in the GUI. ( like altitude, speed, gps details, etc etc ) ... most of the work here has gone into making the underlying communications system operate well, so the mavgui GUI's not yet "perfect" by any stretch of the imagination.... but it's a start.....
Just thought you'd all like to know....... :-)
Buzz.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
207 members
24 members
52 members
719 members
Powered by
