My Nexus 7 transmitter mount.
3689565348?profile=originalHere's my 5 minute mount using two pieces of scrap plexiglass, standoff screws, zip ties, and two of my daughter's hair bands.  It did want to hang a little backward with the weight of the Nexus on there but I used a couple of velcro straps around the antenna mount to pull the lanyard upward until it hangs from my neck perfectly with no hands.
3689565415?profile=original
3689565295?profile=original
3689565434?profile=original
Here's how it's attached to the bar on the back of the transmitter:
3689565505?profile=original
The correction to the strap to make it hang level:
3689565463?profile=original
  • HK has this in stock at $13.26
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=...
  • Here is my mount I put together with about $20 worth of parts from amazon.com3701721620?profile=original
    @criro1999
    For usb capture we still have the same problems, lack of usb drivers. A more elegant solution would be to do the analog to WiFi encoding in another place, and just display that on DroidPlanner.
    Her is the issue if you want to keep a watch:
    https://github.com/DroidPlanner/droidplanner/issues/42
    The main reason why we don't have it yet is because I don't have the FPV gear (so not much motivation to do it).
  • Arthur,
    When do you believe we can see the video capture (FPV) on Nexus7?
    Last time I put this question on last summer, was related to missing video capture card for android.
    Any news since that time?
    Cool, great to see DP there :)
  • @Jeff: Nice out-of-the-box thinking there. I tried to come up with a good way to attach to the back handle with no luck. Plexiglas and hairbands - love it!
    @Glenn: nice integration of video!
  • I think that one I linked is for the 2012 nexus 7. Just look on ebay there are loads to choose from.
  • @Glenn,
    Is the case for Nexus 7 (2) 2013?
  • I'm using this style case from ebay.
    I just drill 3 pairs of holes in the bottom of it, and use thin zip ties and a layer of 3m foam tape to secure it to the bracket.
  • Where you keep battery for monitor?
