3689615178?profile=original
We have developed a suite of mobile and cloud / desktop applications on Android, iOS app and RPAS / sUAS / UAV / Drone Job Management website that integrates with your mobile devices called RPAS Logger (Remotely Piloted Aircraft System = RPAS ) to be used as a drone logbook.
The apps include a bar code scanning feature for battery / maintenance management and our latest (most requested feature) allows you to use your GPS location on your mobile device to show you the nearest airport / helipad etc to your current location which will help in completing your Risk Assessment for each job or flight. www.rpaslogger.com
RPAS Logger EnterpriseThis is the flagship version of RPAS Logger. Unlike the Lite and Pro version, RPAS Logger Enterprise is a cloud-based solution. All Data is kept in the web application and your mobile devices will now become access points that you will be able to use on and off line to collect and log data.
It is oriented towards a commercial operation. It will allow you to create jobs for customers, assign equipment and personnel to different jobs, manage area approvals and risk assessments, manage maintenance requirements and inventory.
Modules will include:
Basic Module – everything required to create jobs, manage airframes, batteries and role equipment usage, manage pilots (including type endorsements and certifications) and produce comprehensive reports.
  • Maintenance Module – Keep maintenance logs for all equipment and manage your inventory - including shelf life and minimum quantity reporting.
  • CRM – Integration into popular CRM modules, or use our vTiger based CRM. Integration for popular financials applications (like XERO)
  • UOC Manuals – online management of your flight, operations and maintenance manuals. Easily update your entire documentation suite with any changes that you make to your fleet, role equipment or operational parameters.
We will appreciate any feedback or request for new features. Rest assured, we have a long list of upcoming features but use your comments to help prioritise our updates.
  • This app is incredible. I found it over the weekend and recently added it to my Nexus.
    I love that you can make your own checklists for pre and post flight, as well as maintenance.
    I'm using your app to establish my flight system protocols for missions.
    My thinking is, follow the Australians since they got it figured out and be ready
    for FAA's decision.
    If anyone needs it, here's the barcode generator I used.
    http://www.barcoding.com/upc/#.VA_5GGSwJVA
  • An app to locate airspace of surrounding airports, is a really good idea. In America, I wish that the FAA would place all AMA flying fields on their GPS maps for pilots of full-sized aircraft. AMA flying field are a fixed hazard, just like high voltage power lines, and are easy for a full-sized pilot to avoid.
  • Only thing missing is a barcode scan for the Pilots :-)
    Looks like a great app and the barcode scanning is fantastic since it allows the lazy to do it and will help prevent errors in data collection.
  • iOS app indicates you are making an app for iPhone/iPad? When will this be available?
    The battery barcode tracker is a fantastic idea!
  • 'bar code scanning feature for battery / maintenance management ' - Just what i have been looking into, Sounds good. Ill give it a try!
