The New FPV  APM  Kopter
In the foreground, the bumblebee
in the background the  Kamkop  with the GoPro 3D system
The new FPV Kopter
made vor 10" Props
to use GoPro or a smal FPV camera
NTM Prop Drive Series 28-30A 750kv / 140w
Motors:
 ESC:
TURNIGY Plush 30amp Speed Controller
Accu:
2200mA
now I'm still working to find the correct PID parameters
 for a stable and no wobbling flight i have to set the P parameter unter 1
than i have not enough sensitivity on my RC
maybe someone has experience with such a small Kopter with relatively large engines!
or someone could rewrite the code for me ?
Peter
Comment by Sebastian Gralla on September 5, 2011 at 2:57pm
well, i think you will have a problem with the propeller overlapping, it causes much vibrations
Comment by Haidar Abu Bakar on September 5, 2011 at 8:06pm
Yes, the props might even strike each other on a fast descent or landing.
Comment by Ryan Beall on September 5, 2011 at 8:36pm
Your P is probably not the issue as much as not having enough D.  Just my guess here, but it would make sense that such a short coupled quad would need more D beings the moment of inertia terms are so much lower.
-Ryan
Comment by Peter Koppendorfer on September 5, 2011 at 11:34pm
Thanks !
i will try the D Parameter !
the Quad is OK ! no Problems with the overlapping !
i fly it also good with the HK System
Comment by Coptaire on September 6, 2011 at 12:30am
This huge overlapping is like having unbalanced propellers.
A propeller increases airflow velocity/decreases pressure and the below propeller has to cope with 2 different airflows on each blades.
Ok, it is... design exploration !
Comment by Guntars on September 6, 2011 at 12:51am
Where do you buy spacers (black cylinders between arms)?
Comment by Peter Koppendorfer on September 6, 2011 at 1:16am
hello Guntars,
the Spacers are from Conrad-Elektronic in Germany !
Peter
Comment by steven jones on September 6, 2011 at 1:55am
hello
What material is this made out off?
How heavy is this quad when it is fully loaded?
steven
Comment by Peter Koppendorfer on September 6, 2011 at 2:15am
2mm GFK
ca. 800g
Peter
Comment by emile on September 6, 2011 at 8:41am
@Ryan with D do you mean P-rate?
As far as I know there is no D term... :)
@Peter
I have been playing with the P-rate and raising it (or lowering it) does make a difference on how the quad reacts even on stabilize mode.
Comment
