New quadcopter from Australian firm
From Wired's Danger Room blog: "Last month, an Australian company, Cyber Technology (WA) Pty Ltd, used a drone with ducted fans in an actual operation. Their Cyber Quad vertical take-off drone carried out an extended survey of an offshore drilling platform and an oil rig damaged by fire. The drone flew around, under and inside the two structures, which are joined by a gantry, as well as landing on them for a better look. “The ability to land the CyberQuad on the various levels of the platform where the main damage occurred gave engineers and disaster control experts the ability to see the extent of the structural damage visually,” Andrea James, head of Communications at Cyber Technology told Danger Room. The Cyber Quad can carry a high-definition video camera or sensors to detect specific gases, like industrial pollutants or chemical warfare agents. The brushless electric motor is quiet and does not produce sparks – important when investigating a damaged oil platform. Top speed is around 40 mph with a mission time of 35 minutes. But this can be extended to some hours, because the drone is able to “perch” on various landing points, and look around from there. “The UAV pilot was able to land and move about on different levels, aiming the camera to get unique and vital viewpoints of the rig structures. This was not achievable using high definition devices from manned helicopters or boats,” said James." Here's the very nice (albeit big) carrying case:
No price given. Presumably it's the "if you have to ask, you can't afford it" category. Video:
  • It actually costs USD 25K-30K, and although it is overpriced, is more than a fancy frame. That kind of frame reduces the dragging around the tip of props, which undergo the highest friction in forward motion. For the same reason rotors can be  closer each other reducing frame arms, so weight. I've seen some DYI drones using this kinds of rings around props by using adapted tins.
    I know a guy who owns one of these CyberQuads.  The price for one is $30,000 and from what I can see (flight modes, startup procedure, controls), I strongly suspect it is actually a Mikrokopter with a fancy frame.
  • How about this ??
    http://www.futurehorizons.net/jetpacks.htm
    Hiller Flying Platform
    The Hiller Flying Platform was a unique VTOL (Vertical Takeoff and Landing) machine developed back in the 1950's by Hiller Helicopter. It was a circular ducted fan unit that utilized 2 counter-rotating propellers. A pilot would stand on top of the unit and by leaning and shifting his body weight he could cause the platform to fly in any direction. Includes patent copy and photos. Much of our flying jetpack development was based on this unit. #HILL info-$10.00
  • Hi Marty, the flights were done as part of our internal testing of the airframe and application. we were very lucky to be able to conduct these tests in a real time application.
  • Another interestiing point is that this appears to be an instance of commercial operation of a UAV within Australia. I was under the impression that this was essentially impossible with the current regulations.
  • Brilliant film...Now all we need is soul control support
  • Avatar has every quad rotor startup pitching their product now that they're a phenomenum.
  • Hi Morli, in answer to your questions, 1) there are currently two versions of the ducted quad rotor, the mini and maxi, the mini will comfortably carry a 400gram pay load with the maxi carrying an 800 gram payload, on the maxi we carry a stabilised 12 mega pixel HD video cam plus a stabilised fly cam used for FPV flying, on the mini we carry a fly cam for FPV plus a multi sensor gas detection system. Both aircraft use a back to pilot live video and telemetry link.
    2) good weight distribution is required on the heavier pay load, however the flight stabilisation system is c of g tolerant to a point.
    3) yes the aircraft is scalable with a larger variant being worked on at present.
    Xander, As we use the quad for gas detection it needs to be spark safe, in fact, "is it spark safe is one of the most FAQ's. and yes we use brushless motors.
  • It looks like it might well only take that camera. Probably just have tilt, thats all one needs on a quadrotor. Looks very pretty tho....
  • Hmm...no sparks. Does that just mean they're brushless motors? Good PR I suppose, but kinda overselling the point. I think every quad uses brushless motors.
