Hi !
I recently started the building of my own UAV
At this moment i´m building the wings 3 meters wingspan.
General description (pictures soon)
wingspan 3 meters aprox 80 dm2 of wing surface
Engine 40cc pusher 3 blade propeller
Tricicle
conventional tail
intended for 1 hr of flight and 2kg of payload
also i´m soldering the ardupilot. (i think gonna need the MEGA version)
yesterday i recive my ArduPilot with the ArduIMU and the GPS.
Comment by Krzysztof Bosak on November 4, 2010 at 4:38am
This looks a little unrealistic. Your platform looks VERY difficult to repair, you will not be able to make 100 takeoffs and 100 landings in 4 days as sometimes required during duning due to engine delays... Get yourself a styrofoam platform and once the autopilot flies on smaller one, switch to larger!
Comment by Martin Bellomo on November 4, 2010 at 9:01am
Yes, you are right
This is the first airframe for testing, then we will make it with fiberglass.
this airframe is for check the measures and the firsts fligth tests.
Comment by Alex Arevalo on November 4, 2010 at 9:08am
It may be difficult to repair, but the structure looks like it would be very strong. It reminds me of the structure of a bridge. At the very least, you will learn something from it. Good luck to you.
Comment by Martin Bellomo on November 4, 2010 at 9:19am
If the plane crashes I need that the structure absorve as much energy as it can, no matters if nothing remains, the payload is very expensive, the airframe is cheap.
Comment by Alex Arevalo on November 4, 2010 at 9:26am
@Martin: that is exactly what the automobile industry does to protect the human payload.
Comment by Krzysztof Bosak on November 4, 2010 at 9:41am
I think your airframe is not cheap to repair in terms of repair time, compared to mass-produced EPP planes. This is why I made a remark initially.
Comment by Ron Jacobs on November 4, 2010 at 12:21pm
Do you have drawings you could share?
Comment by Martin Bellomo on November 4, 2010 at 1:26pm
as soon as I have all the final plans and construction procedures will be sharing all the information
Comment by john bero on November 4, 2010 at 7:46pm
I like it. It looks like you used autocad or equivelent to laser cut this on cnc, is that right? In that case it is not so labor intense or expensive providing you have access to the manufacturing equipment. The design looks robust enough to do what you want. Also this type of airframe should be very durable.
Comment by Jeffrey Torella on November 5, 2010 at 1:54am
Good luck martin your build sounds complex in size but youll get it right
Comment
