$49 without TX/RX modules (available separately). Looks impressive!
From the product listing:
The greatly anticipated Turnigy 9XR has arrived!
The software for the 9XR first began development 6 years ago. Since then it has been tweaked, tuned, changed, updated and revamped by members of the R/C community into a powerful - yet easy to use interface. Our engineers designed the physical product around the R/C communities software changes and input. The culmination of all these is the Turnigy 9XR!
For many users this will be the perfect 9 channel radio straight out of the box, but there are many tinkerers out there who love modifying and pushing the boundaries of what is possible from their radio. We have factory fitted the 9XR with an AVR ISP header to simplify the development of custom software, we have launched turnigy9xr.com as the epicentre for software developers and additional community support for all 9XR users......With the 9XR we encourage it!
The 9XR is supplied preloaded with top quality software which is full of features and yet remains easy to use. Our aim was to develop a radio for you, the hobbyist, with an extensive list of standard features usually expected from a radio system 3 times the price. Our Turnigy 9XR is everything you imagined and more!
9XR Standard Features:
• 8 Channel PPM/9 Channel PCM
• Full Ball Bearing gimbals
• Adjustable Stick Length
• Digital Trims on all Primary Axis
• 16 Model Memory
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate and Exponential
• Sub Trim and Travel Adjust
• Flaps and Differential
• Throttle Hold
• Supports Heli/ Aero/ Glider Model Types
• Programming Templates Based on Model Type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• PPM & PCM Output
• Utilization of JR Form Factor RF Modules
• Programmable Timers
• Low Voltage Warning and Buzzer
• Supports 3s Lipo (Required)
• 9XR Firmware Pre-loaded
• AVR ISP Interface
• Internal 2.4GHz Antenna
Online support and user forums available at: www.turnigy9xr.com
Spec:
Channnel: 8ch ppm/9ch pcm
Display: 128*64LCD (Backlit)
Support Type: Heli/Acro/Glid
Model Memory: 16
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer: Yes
9x's are never in stock, 9xr will be any better?
What makes this better than the old 9X?
Comment by Vadzim Chareuka on December 24, 2012 at 12:01pm New design
Comment by cirilo on December 24, 2012 at 12:17pm It's looking good at least ! Waiting to see a full review of it.
Comment by Jethro Hazelhurst on December 24, 2012 at 1:16pm Yay! Now the 9X will be in stock!
Comment by Jan Detlefsen on December 24, 2012 at 1:37pm is that old remote sold under price with very low stock only to get people coming to check their website over and over again?
I am afraid that new look does not change that it's still old turnigy/hk quality. And yes those stocking issues.. :)
Comment by Ottomite on December 25, 2012 at 2:15am From what I have been reading they supposedly improved the build quality. I hope its true!
Comment by Vincent Mees on December 25, 2012 at 2:59am For the same price it looks better than the old one. So why not.
Comment by c j g on December 25, 2012 at 4:29am ... i was hoping for a 6mode switch. Ok, no need for soldering for firmware-flashing is a little plus ...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
207 members
24 members
52 members
719 members
Powered by
