  • I hope to do a video demonstrating the process from A to Z inclusive on where to source materials/tools in pakistan to do so
  • just finished drilling the holes ended up finding just the tool to hold those super thin drill bits, a pin vice3692158493?profile=originalthats the pcb with the holes, i need to find a generic drill press station
    heres what the pin vice looks like
    3692158422?profile=original
    3692158512?profile=original
  • http://diydrones.com/video/pcb-etching
    its a poor quality video i need to find my digi cam
  • sure ill post pics as soon as i find my misplaced digital cam , i made a small video with my web cam ill post that, soon,
    i tried out two papers one was kodak photo gloss, its no good it sticks to the iron,
    and then i tried out clear paper that is used with overhead projectors and that worked really nice, just wait till it cools before you peel it off, i printed with a laser printer,
  • I use DipTrace for laying out the pcb; print two copies to overhead projection transparency film and then use photosensitive pcb exposed through the two copies of the pcb using UV light. Develop and then etch with ferric chloride and I can easily make pcbs for 0805 SMD parts and 44pin TQFP IC packages. The secret for me is using two printouts of the pcb to give a very good light mask and process consistency with my exposure time (4mins) and developer temperature.
    Peter
    My method if for those that have inkjet printers
  • ferric chloride  that brings back memories  from a time before SMD componets  a long time ago indeed !!
    mahmood,
    what are you using as the resist ?  Back in those days you could get a heat transfer "paper " that you ran thru a laser printer. printing the traces on it, the laser ink acted as the resist and then you ironed the pattern on to the board and carefully peeled it off and then dropped it into the ferric chloride . it worked well enough  that i have at least one dive comm box that has been in daily use (8 hours a day) for more than 20 years . i do not know if the "paper" (plastic sheet with a blue coating ) is even still available or even able to make traces fine enough to do SMD , but if you can find any and have access to a real laser printer it might give you good results . i just did a coursory look and it is still availible  here is one place http://www.dipmicro.com/store/PNPB  you might be in luck finding some in your part of the world
    Good Luck on your project
    Press-n-peel Blue PCB Transfer Paper Film Etch Circuit Board Jewelry - dipmicro electronics
    This paper cannot be used with I
  • where are the pictures? why don´t you show us your S3V3
