Comment by Ritchie on May 7, 2011 at 2:56am
Comment by Daniel Gru on May 7, 2011 at 3:51am
Comment by Rory Paul on May 7, 2011 at 10:46am Very impressive depending on the time it takes to generate the final product. I wonder what their dimensional accuracy is like. They have one 20cm / pixel resolution sample from Gatewing that I am sure they broke some European flight restrictions getting ; )
Comment by MarcS on May 8, 2011 at 3:51am Hi Rory, not so sure if they broke restrictions. Swiss aviation regulations seem to be quite good regarding UAV. At least you can talk to the agencies and are not blocked at first...
I´m quite impressed by the results, too. Question is how much "hand work" goes into the final 3D result? Thats more of an interest then the actual time it takes calculating... The projects I know and have worked on needed a significant amount of ground control points when flying and manual pointing to them when calculating the data This can take several hours or more.... This could be a good point of a DIY competition: Usability without photogrammetric knowledge!
Comment by Mike on May 8, 2011 at 4:04am
Comment by Daniel Gru on May 8, 2011 at 4:33am
Comment by Krzysztof Bosak on May 9, 2011 at 2:54am The result itself is quite impressive, watch mine from 2.6km^2.
Price: this is a service. The answer is 'it depends' on so many ways.
You click the resolution and it displays the price, but what it displays it depends on your contract terms.
Their system looks bulletproof for square areas, I had a few problems only with very elongated map but we are working on it.
PLS keep in mind that well georeferenced ortophoto is around thousand of euros per sq km if it has accuracy required for road construction works - but this is something like data product with atests norms etc. IMO pix4d has output that allows mnaking rigorously those data, on a remote server, without human intervention, some 12h uploading and 24h processing (I got very low priority there yet). This is not something you can make easily on your home computer.
Nice thing it shows the fit accuracy so you have a valid positional report, and you get kml file plus georeffed bitmap as output, + lots more (DEM etc).
You can deduce precision form there.This is a link to the report form our sulphur2 case:
http://ftp.aerialrobotics.eu/pub/sulphur2-2011-04-18/sulphur2cloud_...
This was 70min flight and we did it with double overpass to make it compatible with other, less capable services. We have also reduced crab angle to a few degrees using our realtime wind estimator (self-adjusting flight pattern), just for testing (but this is not helpful for 99% of processing services).
The turbulence and thermals were wild, the altitude was 300m+/- 40m because of 3-4m/s updrafts, very sunny. The area is recultivated sulphur mine, south of Tarnobrzeg, south-east Poland. Looked so uniform till the horison, but from above, no two lakes had similar colour not to mention about UFO marks all around.
Comment by Christoph Strecha on May 11, 2011 at 12:44pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.186 members
1298 members
24 members
51 members
51 members
Powered by
