Power Distribution Board
3689448710?profile=original
The soldering of PDB was not very difficult thanks to the detailed manual. However, I feel that soldering the Female Dean’s Receptacle first might be convenient as the narrow gauge wires won't came in the path of soldering gun. Though this is not a big issue.
3689448670?profile=original
    Harbor Freight sells a great iron for this work, use it to carve up foam equipment / battery pockets in foam wings too. on sale $12
  • The above pic shows the meniscus effect of the solder. Do you see the sqare end of the 90 degree pins as they sit in the solder? I cleaned the resin off the board with denatured alcohol to make it pretty for the camera. This is the M4 position on the board. Notice the connection for the Deans (seen in the upper left). The pad shows the meniscus and the cooled solder is very clean. A 'shiny' joint is one indication you had enough temperature to cause the components to bond well. I used a resin core solder, Radio Shack 64-009E. It is 60/40 type. 0.032 diameter.
  • Different kinds of solder will yield different results. The best kind I have come across is the RadioShack brand 60/40 Rosin Core Solder ( for light duty)  This kind of solder melts quite well and adheres to the PDB without effort. The result is a very strong bond, using this solder you will think you are a pro. I had previously purchased one of those tube enclosed versions from Frys and the result was some ugly soldering and it wouldn't hold, any slight tug and it would come apart.
  • As stated, here is a close view of one section of my board.
    3692375457?profile=original
  • Don't be discouraged but there are several poor to bad solder joints on your board.
    I assembled mine yesterday. The Deans are suspect but your 90 degree connectors have several glob-like joints.
    A good solder joint has a 'meniscus' look to it.
    HERE is a pdf on soldering practice - and that the key to successful soldering.
    I will take a photo of my board as an example for you and post later.
    http://www.ece.ualberta.ca/%7Eee401/resource/manuals/Solder01.pdf
  • At last, an ultrasonic solder removal tool, for disconnecting those joints which just don't come undone by heat alone.
  • Good idea.
    Another piece of advice is that you need to get the deans lugs REALLY hot in order for the solder to adhere properly. Just melting solder onto cold brass with an underpowered iron sometimes means it is not welded properly, and in bad cases it just chips off with your fingernail.
