From Seeedstudio's site:
Time frame for pre-order: Jan. 31- Feb. 18, 2013Time of shipping: April, 25, 2013Ever wanted a development kit that flies? Well now you can! The Crazyflie is an open source nano quadcopter kit designed for flexible development and hacking. It's among the smallest in the world, weighing only 19 grams and measuring 9 cm motor to motor.
Features:
- Small and lightweight, around 19g and about 90mm motor to motor
- Flight time up to 7 minutes with standard 170mAh Li-Po battery
- Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery
- On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle
- Radio bootloader which enabled wireless update of the firmware
- Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM)
- 3-axis high-performance MEMs gyros with 3-axis accelerometer: Invensense MPU-6050
- Available footprints to manually solder magnetometer HMC5883L/HMC5983 or/and barometer MS5611 (sensors not included)
- Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included)
- 4-layer low noise PCB design with separate voltage regulators for digital and analog supply
Price is US$ 149
More information on the site
- 6DOF: http://www.seeedstudio.com/depot/preorder-crazyflie-nano-quadcopter-kit-6dof-with-crazyradio-bccfk01a-p-1364.html
I am currently looking into this to use on my Mini Heli I mentioned it in my video. Check it out and let me know if you think it could work.
Blog HERE!
