Here are some photos of my new pulse width modulated (PWM) hotwire foam cutter prototype.
Find more photos like this on DIY Drones
I use it for cutting foam of all types. Instead of moving the wire, I move the object to be cut. In this way it is possible to make straight and 90 degree cuts referenced to the base plate. I have drilled a hole in the baseplate for the hot wire to run thru.
My new airframe that can contain a lot of electronics will be cut by this cutter.
Its not CNC controlled, however the PWM controller can be used for a CNC controlled unit (plans in progress).
I use a power fet and a Atmel controller do do the PWM control. It can accept PWM commands from a host PC or analog input via a A/D port.
Comment by UFO-MAN on August 12, 2009 at 12:26am
Comment by NingNong on August 13, 2009 at 6:11am
Comment by UFO-MAN on August 13, 2009 at 9:22am
Comment by Cronselaar on August 13, 2009 at 1:16pm
Comment by UFO-MAN on August 13, 2009 at 1:25pm
Comment by Sam Harbold on December 10, 2009 at 7:32pm
Comment by UFO-MAN on December 17, 2009 at 10:57am
Comment by UFO-MAN on December 17, 2009 at 10:58am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.87 members
183 members
47 members
692 members
51 members
Powered by
