Taking my TBS DISCOVERY for a long range flight across my backyard alpine wonderland. How do you manage extreme long range with quadrotors? With some careful pre-flight planning and a battery-swap-team on the mountain!
Comment by Marooned on October 4, 2012 at 6:07pm
Hehe, nice idea :)
Comment by Jay Bryon on October 4, 2012 at 6:33pm
Nice video, all the battery changes were fun.
One note, it's not AGL but MSL, unless your unit of measure was millimeters...  AGL refers to ground level under the aircraft, so you looked like you were 20'Ft AGL while much more than that MSL.
Comment by Jack Crossfire on October 5, 2012 at 12:54am
If someone has to drive there to change batteries, what's the point of flying there?
Comment by Tilman Baumann on October 5, 2012 at 3:49am
Nice Battery relay.
But also showing why I don't really like rotorcraft. On a fixed wing you could have probably maxed out your video and TX range on one battery easy.
Nice scenery though.
Comment by Hooks on October 5, 2012 at 6:55am
King! To all other, try fly your multi to max range.. Then you see the point of this video.
Comment by Crasher on October 5, 2012 at 12:19pm
Frm what I've seen of the discovery, the intended Lipo position looks as if the CofG is way off centre. Is this the case?
Comment by trappy on October 5, 2012 at 2:21pm
Thanks Hooks.
Jack Crossfire, the point is everything in between is flown. The last mountain takes 1hr from the launch spot to the peak, the quad does it in 3 minutes and can see it from perspectives never seen before.
Crasher, no, it's not. The battery position corrects the CG nicely.
Comment by Jake Bayless on October 5, 2012 at 2:28pm
Great fun. Would be sweet if you would edit the video to show where you are transmitting from... given line-of-sight, I'm guessing you are way off down in the valley somewhere? Thanks for sharing this.
Comment by trappy on October 5, 2012 at 2:32pm
Jake, the pilot is at the launch spot at the start :)
Comment by Luke Olson on October 5, 2012 at 2:46pm
I enjoyed watching that a lot. You have some nice friends to help out along the way!
Comment
