Anybody know anything about this one? It's $35 from Roboshop:
  • 2.5dbI high gain and selectivity ceramic antenna
  • MMIC BGA715L7 from Infineon power amplify IC
  • SAWF (Surface acoustic wave filter) form Murata
  • HMC5983 from Honeywell geomagnetic
The Radiolink SE100 GPS Module for PixHawk exceed the limitation of IC sensitivity index from circuit schematic design to PCB placement.1 meters positional accuracy, positioning in 23 seconds and valley station keeping ability.
Specifications
  • Positional Accuracy: 1m precision when working with concurrent GNSS, 2.5m precision when working with single GNSS
  • Velocity precision: 0.1m/s
  • Max height: 50000m
  • Max speed: 515m/s
  • Max acceleration: 4G
  • Max update rate: up to 18Hz
  • Sensitivity Tracking & Nav.: -167dBm; Reacquisition:-163dBm; Cold start:-151dBm; Hot start:-159dBm
  • Time to first fix: Cold start: 26s, Hot start: 1s
  • Connect ports
  • Power supply: voltage 3.3VDC+-5%, current 50~55mA
Ports
  • A.GPS UART interface, baud rate: 1.2K/4.8K/9.6K/19.2K/38.4K/57.6K/112.5K
  • B.Geomagnetic I2C interface
Comment by Jerry Giant on June 14, 2016 at 1:03pm
i saw one was teared down.
UBX-M8030-KA and a LNA.
it works.
Comment by Crady von Pawlak on June 14, 2016 at 2:52pm
Can't find any actual photos or reviews.
Comment by jackson on June 14, 2016 at 10:46pm
   http://radiolink.com.cn/doce/product-detail-115.html     Produced by a manufacture from China,
Comment by Rob_Lefebvre on June 15, 2016 at 5:06am
I wonder what the actual performance is like?  As we know, the specific implementation actually does matter.  Just because the same chips are employed, does not mean the performance will be the same as properly engineered alternatives.
Distributor
Comment by RC Tech.se on June 15, 2016 at 5:33am
Is that pure Kryptonite in the center of it?
Comment by RPM on June 15, 2016 at 6:15am
Ceramic? Weight/dimensions? Those specs are not even on the radiolink website.
Comment by Paul Meier on June 15, 2016 at 6:27am
see RC Tech.se description....
Comment by Nikola Rabchevsky on June 15, 2016 at 7:24am
This would seem to emphasize the importance of good GPS antennas.
Comment by Markus on June 17, 2016 at 6:59am
I have this gps is not good the droteck is 2x better , droteck 15sat hdop 0,78 radiolink 7sat hdop 2,05
Comment by JB on June 22, 2016 at 1:47am
Hey Markus.
Could you please tell me which droteck GPS exactly you mean?
Thankyou!
Comment
