The communication Research Center of Canada maintains a website where we can predict the coverage of our emitter (RX, video, telemetry, ....) in Canada (it may work for the rest of the world but I didn't test it).
you need to create a login/password, it's free then fill the characteristics of your emitter (freq,power, ...) place the emitter on the map and select the coverage area you want.
Comment by olympio de carvalho mendes neto on August 13, 2012 at 5:15pm What means this measure unit?
I registered.
Seems working at Brazil.
Comment by PeteD on August 13, 2012 at 7:23pm I probably just uses terrain data and assumes a line-of-sight link. Does it allow you to specify an altitude?
Comment by Bertrand Duchiron on August 13, 2012 at 8:17pm The measure unit is a conversion from dBm to dBv/m, I am not a specialist of RF, there is table of conversion between the unit used here and the dB/m ( http://www.phys.hawaii.edu/~anita/new/papers/militaryHandbook/field... )
Yes, you can specifiy the altitude of the emitter.
Comment by Daniel on August 13, 2012 at 9:10pm Works great in Hellas , Crete region. Thank you Bertrand
Nice one, I needed this for something else thanks Bertrand.
Comment by Delfin Magote III on August 14, 2012 at 10:49am works great. great tool for predicting your RF coverage.
Comment by Artem Grigoryev on August 27, 2012 at 9:17am Doesn't seem to have correct datum for my area of interest (CA). LOS and coverage area is incorrect for areas with high hills
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.110 members
9 members
182 members
1289 members
140 members
Powered by
