Skywalker Smart Twin-motor FPV Aircraft
    Skywalker Smart is first racing aircraft from Skywalker that has twin motor with strong energy.
    In order to satisfy hobbists's need, we launch KIT version on sales. It is well-built racer that has flexible wings, reasonable installation of inner space. It flies flexible and faster.
    You could see decay above the picture, it combines some elements on the banner. Also, there are mark of "caution" on the position of motor. We hope that hobbists could see this point and keep away from crowd.
You could see picture of aircraft from different angle, we use the fiberglass sheet winglet, which it could disassemble(not like plywood winglet as the product manual).
The dimension of Skywalker Smart is above the picture. And you could the specifications as below.
Specifications
Brand:Skywalker
Model:Smart
Material:Imported EPO
Wingspan:996mm
Fuselage:430mm
Wings area:25.9dm2
Flying weight:750-1000g
C.G:From nose behind 240-250mm
Take off:Hand cast
Landing:Glide down
Recommended Configuration
Motor:2206KV1850-2050*2PCS
ESC:30A*2PCS
Servo:12G*2pcs
Props:5045E/EP*2PCS
Battery:4S 1500-2200mah
Radio:3CH 2Servo
Product details
    If you have any question, you could contact with me at Sales@skywalkermodel.com. Also, my skype is skywalker-ellen@outlook.com.
Comment by Ellen Zhu on December 1, 2017 at 8:11pm
Comment
