Skywalker Titan 2160mm FPV Aircraft Model
    Skywalker Titan is first V-tail aircraft with twin-motor from skywalker. Skywalker Naja is the first V-tail of Skywalker that is equipped with good and steady flying function.
   Skywalker has launched new aircraft model in Shanghai International Model Exhibition and China Expo. This is Skywalker Titan that is V-tail design after Skywalker Naja. Also, it is new twin-motor aircraft after Skywalker EVE-2000 and WALL-E2000.
Skywalker Titan
Wingspan:2160mm
Fuselage length:1230mm
Wing area:52.5dm2
Flying weight:4500-6000g
Recommended Configuration
Motor:2816KV650*2pcs
ESC:40A*2pcs
Servos:17g*2pcs 12g*4pcs
Props:1170E/EP
Battery:6S 16000-32000mah
Radio:4CH 4servo
UBEC:6-8A
Characteristics
1.Adopted EPO material, light and sturdy.
2.Reasonable layout, high aerodynamic performance.
3.Large capacity cabin, reasonable area distribution,such as parachute cabin, camera slot, GPS and other professional platform.
4.Stable and flexible flying.
5.Module design, disassemble and assemble easily and conveniently.
6.Special winglet design, small resistance, long range, precise operation.
Skywalker Titan is in the process of package....
Our engineer install Skywalker Titan to test the aircrafts....
    On aspect of design, we adopt black protection cover under the fuselage. Its design this part to make a certain protection when it lands on the ground. Mor detail, you could consider to buy one and hope you could enjoy it~~
Comment by John on November 20, 2017 at 7:50am
NIce one, what is the endurance with maximum battery and extra payload of 1kg/
Comment by Ellen Zhu on November 20, 2017 at 8:33pm
@ John the endurance is according to your configuration. It has large capacity, the flying weight is less than 5KG.
Comment by John on November 20, 2017 at 10:53pm
what is the weight empty?
Based on your configuration, what was the maximum endurance and what was the battery capacity and cell?
We need also the internal fuselage dimensions.
Comment by Ravi on November 21, 2017 at 6:02am
can you please provide internal dimensions of payload bay. ideal for dropping medicines.
Comment by Ellen Zhu on November 22, 2017 at 11:45pm
@Ravi Thank you for your attention to Skywalker Titan. This aircraft is good for sending medicines because we design special position to place goods there.
That is the main inner space that you could see from the picture above. Also, the end part of fuselage is sharp , that is for parachute position.
There is suitable position for placing goods, you could see as below.
Comment
