SmartAP 4 and other products available!
Sky-Drones has recently announced the release of SmartAP 4 - the latest generation autopilot. Now, SmartAP 4 and other products are available for purchase in online store. All SmartAP products are based on custom hardware and software and oriented at the wide range of applications, including hobby, professional and industrial ones. The key features of the systems are easy configuration, excellent flight performance and intuitive ground control station. More information can be found on the official website http://sky-drones.com/ and in the description below.
SmartAP 4 Flight Controller
3689692319?profile=original
Specifications:
  • Powerful microcontroller 32 bit 168 MHz STM32F4 ARM Cortex M4
  • Compatible with GPS/GLONASS receiver
    - UBlox NEO8, GPS/GLONASS, up to 24 sats, 10 Hz) active antenna
  • Up to 12 PWM I/O support (5V out)
  • USB interface for configuration / firmware update
  • Various communication lines (UART, I2C, SPI)
  • MicroSD, 4-bit SDIO interface for data-logging / parameters storage
  • Backup battery for RTC
  • 2x ADC inputs for battery voltage / current monitoring
  • Electromagnetic sound audio indicator
  • 3-channels LED support (up to 500mA / ch)
  • 2-channels solid state relay
SmartAP 3 Flight Controller
3689692276?profile=original
Specifications:
  • Compact board size of 8x8 cm (3.15"x3.15"), weight 60g, 6 layers PCB design
  • Power supply from main LiPO battery (3S - 8S) support, up to 36 Volts
  • Power supply from BEC 5V support
  • 12V, 5V, 3.3V generated onboard
  • Integrated telemetry module (100 mW), external module is supported as well (up to 5V@1A powered)
  • Up to 24 PWM I/O support (5V out, high-power), SBUS support
  • Various communication lines (UART/USART, RS232, I2C, SPI)
  • MicroSD card driven by 4-bit SDIO interface for data-logging / parameters
  • Backup battery for real-time clock and GPS receiver
  • Integrated main LiPo battery voltage monitoring
  • - Electromagnetic sound audio indicator
  • - 4-channels bright LED support (up to 100mA/ch)
Flight performance
  • Extremely stable flight in stabilize (user control), position hold (semi-autonomous control) and auto (fully autonomous navigation and control) modes
  • Native support of SmartAP Ground Control Station and Configuration Tool
  • Accurate GPS Position hold (up to 40cm), manual position override
  • Accurate Altitude hold (up to 10 cm), manual altitude override
  • Fully autonomous waypoints flight
  • Return to home mode
  • Failsafe detection and event triggering
  • And many more…
SmartAP GCS (Ground Control Station) is the software application which allows you to plan autonomous mission for SmartAP Autopilot as well as control the drone using intuitive high-level commands:
3689692212?profile=original
Also, SmartAP GCS supports real-time video display:
3689692233?profile=original
More information and ordering at http://sky-drones.com/
