Further progress requires starting to desolder the Heroine 2200 boards. That was the 1st robot. The ages from 25-30 were spent purely devoted to that 1 thing, while everyone else was clubbing & getting married.
Heroine 2200 would still be a working robot, with new electronics. She was very unreliable with the old electronics, but modern vision systems & high bandwidth I/O could give her the accuracy to do the job.
There isn't a rationale for an automated method of organizing media. A human can get up & change it much faster than a machine.
For another sonar recap, built up a send & receive test jig. The transducers do 24.5khz.
The sampling rate was a killer in the original. The original did 74khz. The oscilloscope does 130khz with 2 channels & 266 khz with 1 channel, still getting a lot of aliasing. The oscilloscope has a lot of quantization when using 2 channels & aliasing, even at 130khz.
There's no obvious problem with the LM324 preamp. The problem with sonar is the transducer doesn't start up instantly. The background noise is manely echos. A cheap ARM doing the full signal processing at a high sampling rate will be cheaper than an analog system.
Comment by bGatti on July 6, 2012 at 6:34pm Cool
Comment by Carl La France on July 6, 2012 at 7:02pm Jack you really are Brilliant the rest of us sit in Awe! I a familiar with under water Sonar where the Fluid acts basically like a solid and there is echoes and re echoes " Noise " In air the amplitude would have to be turned up or the beam focused into a point to get a accurate reading . why not a miniature forward looking low frequency raster scan radar? tied to auto pilot? don't Know? Just throwing it out there? Have a Good day!
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.133 members
183 members
1299 members
24 members
48 members
Powered by
