Good ideas for next year!
If it involves machine vision, you're certainly the go to person for that.
It would be great to see you field an entry.
Comment by Jack Crossfire on June 25, 2012 at 3:42pm Sadly, no budget, but it was amusing to wonder how it could be done.
Comment by Seth on June 25, 2012 at 4:16pm Why a large vertical stabilizer and small wings?
From my trip last year, I found that the air vehicles had a huge disadvantage over the ground vehicles. I believe your time started when you crossed the start/finish and ended when you "landed" not just crossed the start/finish again. It was a dangerous situation with buildings, cars and pedestians everywhere (see Chris Anderson's crash into a baby stroller - empty at the time). The simplest and winning approach was indeed encoders on the wheels. The downside was the change in temperature appeared to cause havoc on their sensors (but I don't know why) as it went from snow on the ground in the morning to 60's in the afternoon. So there was one guy that probably did 50 test runs around the building and I believe was the cause for the "no test run" policy this year. After every heat, there he was, launching his car, running around the building, grabbing his car, back to the tent to tweak.
I think Sparkfun needs a new location for this even if they want to keep flying vehicles (and I'm not sure they do). With the horrible GPS reception and the big cell tower booster on the side of the building, in a year or so, it will become the Sparkfun encoder competition. But the event is as much a marketing campaign & open house as it is a UAV competition....so they're not likely to change venues. The encoder guys will continue to get faster and faster and it will have all the excitement of the toy cars at Walmart where you can pre-program how many times it goes forward and then it turns and then goes forward and then turns....only they'll be doing it at 35MPH which will make for spectacular crashes. I think they should add a gravel patch after the first turn which will completely eliminate all the encoder teams....
Novel, yes, practical, no. Nice people, good time, not much of a competition.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
693 members
51 members
249 members
Powered by
