If you are looking for a nice way to mount all of your gear onto your multi rotor frame, you should have a look at our new stack up plates. On the product listing you can choose what components you need so that you can create your own stackup.
If you are using AIOP or Multiwii boards with the same 5cm x 5cm footprint then you can also mount the included PDB on the stackup as shown.
You can also use some Vibration Dampers on the stackup for the flight controller.
If you are using an ArduPilot Mega 2.5+ board, then you can mount it as shown, you will also need to use some double sided tape to secure the board down. This is a good idea because it also reduces the vibrations on the board so it will perform better.
Comment by Andrew Radford on January 31, 2013 at 3:51pm Interesting - I bought something similar from ebay but it is really thick glass fiber - 3mm I think so very heavy, These would be perfect for mounting minimOSD, telemetry etc if they had holes/slots for zip ties to go through
Comment by Jeremy Zawodny on February 5, 2013 at 5:54pm Doh. Out of stock. :-(
Hmm why always Carbon? Don't people really know that you should not use carbon. Carbon is bad when you have a lot of radiosignals, electricity etc as it blocks RF signals and also can transfer electricity so if you have even minor leak on cabling in worst case you will burn all your electronics. That's why on jDrones and 3DR ArduCopters use normal FR4 or G10 fiberflass as they don't create problems.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.110 members
9 members
182 members
1289 members
140 members
Powered by
