Hard landings with my 3DR quad always puts it firmly 3 inches into the ground, splitting the legs up and destroying the nylon spacers.
I created these very simple bumpers so i don't have to dig up my quad anymore:
They are made from pipe insulation and a wooden hub from a broomstick i had laying around.
I cut up the stick in four 18 mm pieces to replace the nylon spacers and drilled a 3 mm hole in the center.
CA glued the hub to the middle of the foam piece and cut openings for the two legs.
Finally i replaced the two short 3 mm screws with a longer one that goes through both legs and the hub, securing it with a locknut.
Comment by R. D. Starwalt on February 6, 2013 at 5:11am
Very clever! There have been a few discussions about the legs over the months.
Your solution is cheap and effective. A+
-=Doug
Comment by Alex on February 6, 2013 at 5:15am
Very good solution!  Simple, lightweight and cheap!!
BTW where did you get the red arms from?
Distributor
Comment by RC Tech.se on February 6, 2013 at 5:19am
Thanks guys! Alex, i painted them :-)
Comment by Emery c. Chandler on February 6, 2013 at 9:25am
in texas we use mud tires XD no this was a very smart idea, it would be wise to think of different situations that can occur because of our landing spot. mud is one of many things.
Distributor
Comment by Dany Thivierge on February 6, 2013 at 11:25am
Very nice solution, give the legs less "biting power" on surface too! I like it a lot!
BTW I sell the red arms (but for legacy 3DR frames using 28cm arms compared to the new ones 24cm)
RED replacement Arms
Dany
Comment by Jiro Hattori on February 6, 2013 at 3:46pm
I make similar landing gear bumper for Turnigy Talon V2.
Comment by Darrell Burkey on February 6, 2013 at 11:15pm
You can do the same thing with pool noodles. Cheap, easy to source and come in lots of colors. I think the way you have them mounted works better than in this photo though. On the hexa I'm now mounting them like you do:
Comment by abgdn.fireman4678 on April 23, 2013 at 6:00pm
Thanks.  This helps me a lot.  I needed something like this.
Comment
