Tarot T-2D Gimbal connection to Windows 10 Info
Hello everyone,
I have connected a Tarot T-2D gimbal to Windows 10. Since I could not find anything about it, I thought to post the pinout, mostly so I do not forget it.
So the problem is that the standard usb adapter delivered with the Tarot T-2D uses a Proliferic chip, which only seems to work on Windows 7. I could not test it, since I lost it.
What also works is this:
-Use a normal FTDI adapter
-Set the baud rate (very important) in the device manager:
The pinout is above.
Comment
