As drones are increasingly used in inspection, surveying, and security missions, the demand for reliable long-range distance measurement has grown steadily. Laser distance modules are often integrated into optical gimbals to provide distance data that complements visible or infrared imaging.
This review evaluates the TC25 Laser Distance Module from a drone gimbal integration perspective, focusing on its design, performance characteristics, and practical suitability for aerial applications.
1.Key Specifications
The TC25 is not designed as a high-speed obstacle avoidance sensor or a LiDAR replacement. Instead, it is positioned as a long-range, low-frequency, directional laser ranging module, intended for distance acquisition rather than real-time control.
Key specifications include:
- Measuring range: 3 – 1200 m
- Accuracy: ±1 m
- Measurement frequency: 1 – 3 Hz
- Dimensions: Φ25 × 43 mm
- Weight: ~15 g
- Laser wavelength: 905 nm, Class I
- Power consumption: <330 mW @ 3.3 V
- Interfaces: UART / RS485 / RS232
- Built-in aiming indicator, optional red or green laser pointer
From a specification standpoint, the TC25 clearly prioritizes range, integration simplicity, and operational stability over ultra-high precision or fast update rates.
2. Mechanical Design and Integration Evaluation
In drone gimbal systems, mechanical form factor often plays a decisive role. The TC25 features a 25 mm cylindrical housing, which is particularly well suited for gimbal integration.
Key observations from an integration perspective:
- The cylindrical shape simplifies mounting and alignment
- It allows coaxial or near-coaxial installation with visible or IR cameras
- The compact 43 mm length fits well inside small to mid-sized gimbals
At approximately 15 grams, the module introduces minimal payload impact, making it compatible with many multi-rotor drone platforms. Overall, the mechanical design appears intentionally optimized for embedded and OEM applications.
3. Ranging Performance in Aerial Use Cases
Long-Range Capability
The most notable advantage of the TC25 is its maximum range of up to 1200 meters, which is highly relevant for aerial operations such as:
- Air-to-ground distance confirmation
- Long-distance target measurement (buildings, towers, terrain, vessels)
- Inspection and monitoring tasks requiring extended standoff distance
While the ±1 m accuracy is not sufficient for high-precision mapping or fine control loops, it is more than adequate for distance confirmation, situational awareness, and target referencing in drone missions.
Measurement Frequency Considerations
With a measurement rate of 1–3 Hz, the TC25 is clearly not intended for:
- High-speed obstacle avoidance
- Real-time flight control feedback
- Indoor SLAM or navigation
However, in gimbal-based applications—where the sensor is typically locked onto a target and distance is read periodically—this update rate aligns well with real-world operational needs.
4. Built-in Aiming Indicator: Practical Value
The TC25 includes a built-in aiming indicator, with optional red or green laser pointer configurations. From a reviewer’s perspective, this is a particularly practical feature for drone gimbal integration.
Its benefits include:
- Faster optical axis alignment during assembly
- Clear visual confirmation of ranging direction during calibration
- Simplified field setup and maintenance
In many cases, such integration-friendly features significantly reduce engineering and commissioning time, offering value beyond raw performance metrics.
5. Interface Flexibility and System Compatibility
The TC25 supports UART, RS485, and RS232 interfaces, providing flexibility across different drone and gimbal architectures. This makes it compatible with:
- Gimbal control boards
- Embedded computers (e.g., onboard processing units)
- Flight controller auxiliary interfaces
Power consumption below 330 mW @ 3.3 V is also advantageous for aerial platforms, where energy efficiency directly impacts flight time.
6. Suitable and Unsuitable Application Scenarios
Well-Suited Applications
- Drone gimbal distance measurement
- Long-range air-to-ground or air-to-target ranging
- Inspection, surveying, and security missions
- Directional, low-frequency distance acquisition
Less Suitable Applications
- Real-time control loops
- Applications requiring high refresh rates or centimeter-level accuracy
7. Review Summary
From an evaluation standpoint, the TC25 is not a universal drone laser sensor, but rather a well-defined, purpose-driven ranging module.
For drone gimbal systems where the primary requirements are:
- Long-distance measurement capability
- Compact, integration-friendly mechanical design
- Stable and predictable performance
- Simplified alignment and calibration
the TC25 represents a practical and engineering-oriented solution.
Its strengths lie not in speed or ultra-high precision, but in range, usability, and system compatibility, making it a strong candidate for gimbal-based drone applications that require reliable distance information rather than real-time navigation data.
