The popular DIY Drones Telemetry Kit is back in stock and better than ever! It now includes a custom XtreamBee adapter-to-APM cable. No more fiddling around with jumper cables and having to check if one fell off (or dealing with bricked Xbees because of a loose power connection). Same price as before ($150.00)
You can also buy the cables by themselves ($1.50)
Great addition, this cable makes connection much easier!
Just a suggestion, it would be also good to produce and sell this cable with angled connector on APM side. It's not always possible to use the straight one, I faced this problem while assembling ArduCopter; if you want to use it in "X" frame configuration, wires from connector will abut into the plate and won't allow to mount a board (I attached the photo and it shows how the problem could be solved).
