Test Sonar wiring Shield Perfect No Noise
Today I'm test sonar my Arducopter in ALT Hold Mode. I use USB HUD cable (Have Shield) connect to Pitot port IMU and receive signal from AN (pin 3) the Sonar. It perfect not noise in test.
Now, I use code ArduCopter2.0.39b
Wiring shield to ground at Sonar.
And connector to Pitot port IMU.
Installer to sonar mount under main frame.
Red line is Sonar Alt , Green line is Baro Alt
2554-09-04%2002-42%202.log
Comment by Heino R. Pull on September 4, 2011 at 7:53am
That looks really good - it is so important to use the sonar/baro alt logging function to check your sonar noise performance and not just trust the CLI's sonar values. Until my sonar's plot matched my baro plot like yours does,  I was getting very intermittent alt hold performance.
Comment by Balloon on September 4, 2011 at 8:30am
I use cable shield from old USB Hub. I'm solder Shield line to GND in sonar and IMU Port (Pitot Port).
When, I change ALT Hold Mode. It high performance and rather Stable level. Yeah !!!!!
In Log I change ATL Hold Mode in period 1200 - 2200 line number on the graph
Comment by Markus Wolfarth on September 4, 2011 at 11:19am
I use a shielded Microphonecable as well :)
Comment by Balloon on September 4, 2011 at 11:29am
It's work.
Comment by Björn Geir Leifsson on September 6, 2011 at 8:29am
A real shielded cable is of course the way to go.
I just wonder...
Can any of the electronics guru´s tell us if a twisted three-wire lead would give the same or sufficient shielding effect?
Twisted servo leads is a common technique used in the RC world and said to diminish RF interference in longer leads by a cancelling effect. Many also use ferrite cores that the servo leads are wound through a few times.
Twisted wire example  Ferrite core filter example
Comment by Balloon on September 6, 2011 at 9:20am
What're you have sonar graph ?
Becuase, I be used ferrite cores but It have some noise. TT_TT
Comment
