Tethered - but flying ... the story of an APM 2.5 on a stock F450 quad frame
Here's a video, of my stock DJI F450 frame quad tethered to a plywood slab in my basement - where I'm learning to fly in different orientations in stab mode.  Tether saves me from heavy fingers while learning, simply too much blizzard outdoors to fly there these days,
The tether was nylon string attached to bottom of quad.  I'm tuning the stock APM params now - so far, I've done these ,,,
Non-default PIDs I've changed so far
  • Ang Rate P: 0.14
  • Stab P: 4.0 - this change from 4.5 made the quad much more docile in hover
Once I can circumnavigate the plywood on the floor, stopping to hover over each corner for a few seconds -  and I can do this in all 4 yaw orientations - without pulling the string taught - then I can untether the quad in my basement,
Here's a pic of my setup - stock DJI F450 frame, ESCs and motors;  3DR APM 2.5 with PM, 3DR sonar (mounted on balsa spanning two white arms - the front), Castle 10A BEC, a loud and visual low battery indicator,  and a lot of hope.  Using a 5800 3s Zippy LiPo - getting 20 min flights with this setup.
And here's my Z accel data ,,,
Comment by OlivierD. on February 2, 2013 at 10:00am
Great setup Tim, seems like a good way to get some practice. What does the copter do when it reaches the end of the string, does it jerk and self-right immediately? I am worried it might freak out and crash no? Perhaps a piece of rubber band at the end of the string to dampen the shock when you hit the end of the rope?
Very impressed with the 20 min. flight time, that is amazing. Question: What do you use the BEC output for?
Comment by Tim Green on February 2, 2013 at 10:25am
OliverD, copter stays level when it reaches the end of the string. Motors rev up a bit, as it pulls on the string - nothing more than that. I've done 5 full flights this way to date. I'd be very hesitant about adding elastic energy to this setup.
I use the BEC to power the output rails of the APM. As DJI ESCs are opto, and have no BEC on them to use for that.
Comment by Neil Ohnemus on February 2, 2013 at 10:36am
Nice Tim, you have inspired me.
I have some work to do getting my hex setup in the basement today!
Comment by jasonshort on February 2, 2013 at 11:22am
4.5 is a good setting for this quad.
I would suggest tuning it on the string if you can. Most likely the rate_D is a little low and Rate P might not be exactly right.
I usually do a quick roll and level it to look for wobble, then adjust rate_P and raise rate_D until I tune it out.
Jason
Comment by Michael on February 2, 2013 at 11:30am
Thanks for the idea! Probably eliminated a crash or fly away for me outside while tuning!
Comment by Tim Green on February 2, 2013 at 11:37am
Be sure that your tether is strong enough for your machine, also short enough not to allow props to strike anything in basement other than the floor, and finally, and heavy enough that slack string lays on floor rather than getting blown up into props.
Comment by Tim Green on February 2, 2013 at 11:38am
And start with a short tether if you've never fired up your props before.
Comment by C. Escudero on February 2, 2013 at 12:26pm
what motors and props are you using? I am buying the same frame. thank you
Comment by Tim Green on February 2, 2013 at 1:13pm
Stock DJI 920kv motors, 30A ESCs and 10" props.
Comment by OlivierD. on February 3, 2013 at 2:04pm
Cool! Great idea. I am building two separate quads and was wondering how I would tune them without breaking 20 props, scratching the furniture and risking all sorts of damage, this is a great way to check that the settings are good enough prior to heading out for good. Excellent work Tim!
Comment
