T3
The new Gluonpilot 2 has been launched...
3689487090?profile=original
Yesterday I received one of the first updated Gluonpilot 2's from Tom Pycke in Belgium,
The Gluonpilot is an open source project created by Tom and the new GP2 is a completely new hardware design but firmware will run on both new and old Gluonpilots.
I have been flying the Gluonpilot extensively this season and I especially like the Ground Control Station which allows route updates during flight and displays everything live in Google Earth.
3689487271?profile=original
Gluonpilot2 specifications from the www.gluonpilot.com web-page;
MPU-6000 based
All needed sensors (including the switched power supply) are on the main board
On-board USB connector
2 voltage inputs for batteries
1 current sensor input
Extendable: all pins are available on the extension board (I2C, SPI, GPS, ...)
Rewritten OSD firmware with unique features: wind indicator, current navigation block name
High-Efficiency switched voltage regulator at 2.5Mhz
Top quality components for optimum performance: X7R capacitors & 1% resistors
Enough solder jumpers & in- & output ports to customize it to your needs
    Here's some interesting reading about SPI and I2C...
    http://electronics.stackexchange.com/questions/29037/tradeoffs-when...
  • T3
    ramboky - thanks - you're right - now I know why both the AMP and Gluonpilot use the MPU6000!
    Still need to check out the APM sometime in the future though! :)
  • T3
    OK, thanks Chris for the insight of the MPU6000/6050 - I guess we'll have to ask Tom about his preference in using the 6000 with I2C interface...
    I guess I need to get check out the APM2 now also... :)
    Thanks!
    Mohammed: Yes, the chips are identical in all other respects. PX4 and APM use the MPU 6000 because it has the superior data interface, but both chips have the DMP.
  • Afff ... most people dont know anythink about sensors !
    Thanks for clearing my confusion Chris, but does the MPU 6000 have sensor fusion too?
    The only difference between the MPU 6000 and the MPU6050 is that the first uses a SPI interface and the second uses I2C. In general SPI is preferred for UAV use, since it's more robust.
    @icebear the MPU 6050 has in-built sensor fusion, thus the main processor can be freed up and used for other tasks.
    The APM 2 uses MPU6050 to take advantage of this.
    FYI we will also be selling these gluonpilot 2 boards from our shop in the UK.
