The Samarai, Lockheed's maple-seed-like drone
Being from Lockheed it's not DIY by any means, but this could be an interesting concept to play with."The Samarai is about a foot long, and has just two moving parts plus a camera. It can be controlled by a remote control or by an app on a tablet computer."
The full article is in the Navy Times.
http://www.youtube.com/watch?v=yvG-AmwVDmc
http://www.youtube.com/watch?v=UY38uho9ZdE
Clearly not a vehicle for FPV unless you could have it transmit 1 image per revolution.
Comment by Yuan Gao on August 12, 2011 at 10:31pm
Is this related to University of Maryland's maple seed copter?
Comment by Pieter van Woerkom on August 13, 2011 at 1:06am
mine running an APM
see topic:jaw-dropping-project-but-need-a-little-help
Comment by Jack Crossfire on August 13, 2011 at 4:50am
But can it draw Marcy 1 & Air Force logos in the air?
Comment by Jhon on August 13, 2011 at 5:40am
whats the sens of this? camera is always in movement, no way to get a decent image
Comment by Lee on August 13, 2011 at 5:50am
I could really use this if it had a real blade to cut down some tree branches way up in the air!
Comment by Geoffrey L. Barrows on August 13, 2011 at 8:01am
The samara configuration is pretty cool. One advantage is a large amount of passive stability since any lateral imbalances are canceled out by the rotation.
@Yuan- The University of Maryland vehicle is a different project than Lockheed's.
Comment by bGatti on August 13, 2011 at 9:53am
This takes the unusual step of including the motor on the wing side of the equation.
Moving the center of mass toward the single wing results in less of the wing moving productively - and in extreme cases, in part of the wing moving backwards through the air.
Still, with enough battery weight etc; it can be reasonable.
Props in the uncontested airstream may outperform props straddling the airfoil - however, we might consider a wing-leading prop to be in the least turbulent air.
Comment by Randy on August 13, 2011 at 6:19pm
very reminiscent of Jack Crossfire's Marcy 1 work.
Comment
