This video is of some loiter testing I did this morning of my Trex450 running the latest arducopter code, 2.0.50.
If it were a quad I might not be super happy with the results but for a traditional heli, I think this is a pretty good performance. The altitude hold is very solid using Jason Short's latest code paired with a maxbotix MB1260 XL-EZL0 sonar which is mounted on the tail using a custom 3d printed mount.
There's some more work to do to resolve the circling (which is always in the clockwise direction by the way). I guess what's happening is that the heli is always missing it's target - so for example if the loiter point is straight north, it's actually heading slightly north-west. I suspect the problem is either:
Also the P and I values need some more tuning to stop any overshoot.
This code is the latest and greatest and can be downloaded from the APMissionPlanner. By the way, if you're not familiar with the arducopter code for the heli, it's 95% the same as the quad code, just some changes here and there to deal with moving servos around instead of motors.
If anyone has any other ideas, comments or advice on the circling or anything else, I'd love to hear them.
I think the orbiting is a combination of the Compass declination being slightly off and the latency of the GPS amplifying the issue.
Jason
Could be that, but I'm sure the control interaction is playing a role. Fact is, when you give forward cyclic, the heli also moves to the left (or is it right...?)
Anyway, looking pretty decent, though I won't be standing that close with my 600. ;)
Comment by Pbreed on October 31, 2011 at 10:30am To get my Trex 600 to loiter well I needed to add a term that uses GPS velocity.
(Basically D term on position)
This was not arducopter code it was my own code It hovered better than I could and rapidly responded to wind gusts etc... With the good 20Hz GPS it looked like It was sitting on an invisble step ladder.
We have a rate controller nested in a position controller so I would have thought that if the speed got too high it would slow it down. Perhaps we (i) should add some logging of the PID values to try and make it easier to diagnose the problem.
In a separate discusion Olivier suggeted either dynamic PID values or a feedforward setup so that might be worth a try as well.
Randy,
I'm testing a new alt hold patch that's better than the current one. I'll fly tonight and push it to GIT. Let me know if you see an improvement.
Jason
OMG, just got back from testing alt hold with a new approach to the barometer sensor. WoW, i've never seen such a good hold and no oscillations at all. The baro drift of a meter or so is still there but it's not bad. Will post a vid soon.
Jason
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
111 members
137 members
693 members
Powered by
