Call for Papers
2010International Powered Lift Conference:
A New Decade in V/STOL
FlightTorque Stabilized Vertical Lifting System (TSVLS)
Abstract – by Charles Medlock
Classically trained engineers have been left with the impression it is impossible to control 100% of the torque generated by a single lift rotor, using only the downdraft, within the same diameter as the lift rotor, because 100% of the torque minus 100% of the torque would leave no useable downdraft or zero lift. This illusion has stymied the development of a torque control system with many potential applications.
The TSVLS solves the problem by locating a lift rotor over vertical airfoils arrayed within a shroud to create “horizontal lift” in an anti torque direction. Our testing shows 100% of the torque can be controlled, balanced, with anti torque forces, even while the airfoils are at a low angle of attack. Our testing also shows the torque remains in balance, except for minor trim adjustments, even when power and load is increased and decreased, because as power is increased, the downdraft is increased and the anti torque forces are increased. The torque control is built into the TSVLS module, making it absolutely dependable.
Our thought challenge was to visualize how man could take off and land from his driveway and fly just above treetop with the least amount of hardware. The TSVLS is our solution to that challenge. The results of that thought challenge has lead us to believe the TSVLS is the cheapest, safest, simplest, absolutely dependable way to accomplish personal vertical flight. The TSVLS could be used in UAVs, as a defensive military platform, to create a 4 to 6 passenger VTOL family flyer, a 2 seat flyer, as an indoor Radio Controlled hobby craft, and in commercial and industrial lifting. We believe the TSVLS will prove to use less power to control torque than any other method currently employed, whether it be a tail rotor, contra rotating props, or counter rotating props.
The TSVLS increases lift/thrust by up to 40% because the lift rotor is located within a type “B” shroud. Airfoils have been shown to create up to 30 times the drag they create. These facts indicate the TSVLS will operate at over 100% of the lift a rotor can produce without it, while controlling 100% of the torque generated by a single lift rotor.
  • T3
    @Gary your image clearly shows the ball is held by telekinesis. This is another patent.
  • I have 4 edfs on my shelf, the all have vanes that do the same thing that your vertically oriented airfoils do, u could have just given me that money you spent on the patent
  • that's not new... even EDFs use that technique....
  • 100%? Why that would be... amazing!
  • Word Salad.
  • From what I can make out, the main difference here is that instead of having actuated flaps/vanes downstream, there are airfoils attached in a fixed position so as to generate moment to counteract propeller torque.  Is that right?  I think the main point being that the airfoils can be in fixed position because the increased torque produced by a faster propeller is supposedly cancelled out by a correspondingly larger "horizontal lift" produced by the airfoils.
    I would be very interested to hear how this is compares in efficiency and controllability with the downstream vanes like the ones linked to by previous commenters
  • Your post is somehow difficult to understand, what you describing is essentially a propeller with vanes downstream, like for example a small rc plane that can hover (like this video). Is that correct?
