Randy posted a great tutorial on using ArduCopter tlogs. Thanks Randy!
Comment by Glenn M on February 3, 2013 at 3:08am That was good. Learned a bunch of things. Thanks!
This is really of huge value! Thanks Randy
A suggestion perhaps for the next one: How & where to spot common problems in the logs and their causes.
Graham,
yes, good idea. There is a list of things I tend to look at whenever I'm going through someone's logs.
What I'd really like to make at some point (or have someone else make :-)) is an automatic log analyzer. So people submit their logs (perhaps through the mission planner) and a program is run over it and comes back with some basic analysis. Anyway, walk before we run..
That would be absolutely amazing! And save a lot of people time and money! Run, run!
Comment by Tim Green on February 3, 2013 at 9:11am
Comment by Andrew Chapman on February 12, 2013 at 12:14am
Comment by Jake Simon on February 23, 2013 at 9:46am I like the TLog walk through!
I'm trying to get a some data on voltage/current data based on various flight characteristics and the only way I've thought of to do that was to convert the .tlog file to a text file, run that text file through a c++ program to generate another text file, and put this final text file into Excel.
I've written the c++ code to do this, but it only records time(indirectly), voltage, current, and altitude. I would post the code, but I can't find how to do that on a blog post. The current code is located in this thread (TLog to Friendlier Format). As I update the code the newer versions will be posted here: quadforge.net.
If you guys have any suggestions for the code please let me know!
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.677 members
1284 members
24 members
4 members
8 members
Powered by
