UAV-to-UAV midair refuelling simulation
From the video description:  "Northrop Grumman video showing its Proteus manned test aircraft (left) and a NASA Global Hawk unmanned aircraft (right) conducting the first simulated autonomous aerial refueling at high altitude. Proteus (acting the the tanker) and the Global Hawk (as the receiver - its the reverse of the normal way) flew as close as 40ft apart at an altitude of 45,000ft in a risk-reduction flight for the US Defense Advanced Research Projects Agency's KQ-X program. Wake turbulence between the aircraft as well as engine performance and flight control responsiveness in the stratosphere were evaluated."
{via Robots.net}
    Yes if they don't have to land at all it makes them much less prone to risk
  • Northrop Grumman is using AARD system of Sierra Nevada Corporation that 5 years ago demonstrated autonomous refueling when one of NASA's F/A-18B received fuel from a 707 tanker. All the equipment was installed in the F/A-18 and as you can see in the video the pilots have their hands over the dashboard during the refueling:
    AARD uses differential GPS, INS and optical tracking. The goal is to have a few only tanker RQ-4 that will be able to refuel all the other Global Hawks. More info: Ares / robots.net / robotpig.net
    They are not the only people trying http://www.suasnews.com/2010/11/2676/ultra-slow-air-to-air-refuelin...
    Skyraider and Seahawk
  • Wake turbulence is a big issue for planes. In a fluid dynamics class I took, we talked about a jet liner that flipped over while it was landing and was completely due to wake turbulence from another plane. I guess i never considered its effect while trying to refuel another plane. having a UAV that could refuel any plane would greatly reduce the risk for in flight refueling procedures. I like it.
  • There was no actual refueling. It was just a test flight evaluating the control algorithms in close formation flight with one craft in the wake of another at high altitude. This is only a test. Having flown close formation flight myself, (my butt was in the plane), I know that wake turbulance from a plane your own size can really throw you around. This is not a trivial matter. It's requires preplanning and discipline from both pilots(human not silicon). They must have used some form of machine vision control to pull this off. Congrats to them!
  • Ah I see. I guess I glanced over the description and saw simulated, so I thought it was going to be 3D modeled. Then when I saw real video footage it kind of went out of my mind. That's pretty amazing none-the-less. I'm curious to know if the two UAVs communicate, and if so how? I'd imagine the latency of satellite communication would be too high for this type of operations.
    Yes, as the description says, this is simulated.
  • Am I blind or did they not actually show the refueling process? It looks like the UAV needing fuel was still trying to get aligned.
