Ublox to nmea converter
Hello:I want to use a ublox gps for two item. A paparazzi autopilot, that need a ublox gps, and a osd that need a nmea code gps. And I want to use only one gps. Is there any kind of ublox code to nmea converter? O something like that?ThanksJesús
  • First of all, Sorry! I´m noto going to do again. Sorry and thakns for the answer. Mark, the ublox gps can give me the two codes at the same time in diferents pins?
    Jesús
    Jesus, first, a housekeeping note: questions should be asked in the discussion forum, not as a blog post. Second, Paparazzi uses uBlox in binary mode, not NMEA, so you won't be able to use an OSD that requires binary unless you use an open source OSD and write your own uBlox binary parser. That's a big project.
    uBlox can send both nmea and uBlox binary, check uBlox manual and u-center configuration software. You will need to parse the combined data.
