The Cooper Union - Unmanned Development Team
UAVforge.net Entry,
The Aeolis UDMA
Let me know about any improvements you guys can come up with, and vote for it if you like it!
If you want us to vote for it, it would help to link to this project on the UAVForge site
Comment by Julian on October 25, 2011 at 10:30pm Its an idiotic Flash Based website, the youtube link is the best i could do.
Ugh. I remember now. My condolences ;-)
I am cobbling together a page of entries http://www.suasnews.com/2011/10/9204/uavforge-entries/ so will add this one. Team Icarus Labs is also using Ardupilot.
http://www.suasnews.com/icarus-labs/
Its here for voting, http://www.uavforge.net/ and yes its a horrid site!
Comment by Edward Strickland on November 3, 2011 at 1:29pm Julian
have a look at these links, http://www.rcgroups.com/forums/showthread.php?t=653652
which eventually developed into http://www.guidedsys.com/VTOL/sicx-300v-uav.php
and i guess this as well
http://www.youtube.com/watch?v=NC33z1QvaaY
this type of transition is unstable, utilizing a stall at height. Better to climb out but this requires power and thrust.
CofG will be your major issue for stability in hover you will need it low.....conversely fixed wing flight will require a fwd CofG. An AP suitable for unstable flight may solve some problems.
Ed
Comment by Julian on November 3, 2011 at 1:58pm I had seen the Vbat at the start of the project, using it as a bit of inspiration and a reminder that "stable" VTOL flight is possible with the CG above the propellor. I am going to be relying heavily on the autopilot to make the airplane flyable, so as to minimize the effects of the compromise between the position of the cg for both flight modes. Im looking at a thrust to weight ratio of about 1.4 : 1 which is cutting it a bit close, but i think it should still be able to make it out of a transition. Im not looking to do a stall based transition, i was thinking more along the lines of gradual arc from vertical to horizontal.
I had seen your comment on someones question pertaining to ducted fan design, any rule of thumbs you could offer? I have a decrease in outlet area on a ~4 degree slope from the inlet area to get a bit of compression, but seeing as this is operating more as a shrouded propeller than a ducted fan, is it worth it? I have a 1250 watt motor that im probably (depending on testing) going to use a 3 Blade propeller on to get a good amount of disc loading in the comparatively small [to the dia of the recommended propellors] duct diameter im using.
Comment by Julian on November 3, 2011 at 2:35pm Alot of other similar platforms rely on the same vane control system with a smaller moment:
Hover Eye: http://defense-update.com/products/h/hovereye.htm
Honeywell VTOL: http://www51.honeywell.com/aero/common/documents/myaerospacecatalog...
Tailsitter Flying Wing: Just found this (to my pleasant surprise) http://contentdm.lib.byu.edu/ETD/image/etd2372.pdf
Comment
51 members
133 members
1298 members
249 members
Powered by
