Updated "NorthEast only" test mode code
I screwed up the original "NE" test mode code (which is used for testing servo direction and correct system setup) and the rudder only turned right. Sorry! I've fixed it and it's now in the Google repository. The video above shows how you can test it. Just walk around after the GPS locks and you should see the rudder respond as in the video.
  • Oh, sorry, my bad, I was looking at the Ardupilo 2.x setup....
    That's correct--it's the standard ArduPilot 1.0 setup. Did I say differently somewhere else? If so, please point me to it and I'll correct it.
  • @Chris, I tested this NE mode code. Found out that the rudder servo need to be connected to OUT2 instead of OUT1 in order to work.
