One of the common questions regarding the use of 4G/LTE on drones is if the connection still works at high speeds. Especially in regard to fast flying fixed wings UAVs.
In particular the Doppler Effect is often stated as the main concern.
Ericsson actually tested this - not on a drone but on a jet!
The results showed that the PCs were able to connect to the internet with a maximum downlink speed of 19 megabits per second while flying at 700km/h and with the force of 4G.
A seamless handover from one radio base station to the next was possible while flying at a speed of 500km/h, without any visible disturbances to a video stream used to monitor the stability of the internet connection.
Sky Drone FPV and Sky Drone Link allow you to get Full HD / UHD low latency video streams and command & control of your drone ove LTE - even at 700km/h.
Source: Ericsson tests LTE in extreme conditions
Comment by Nicholas Witham on November 26, 2017 at 9:13pm
sweet, i'll have to ensure i limit the speed of my next build.
Comment by Ouroboros on November 29, 2017 at 2:07am
Uh, isn't there a rather important point that frequency licensees often have directional limitations, such that terrestrial cellular carriers have to often point their antennas downward to comply? And some other carrier handles aircraft to ground cellular, usually at eye-melting prices? Was this test only with already deployed 4G LTE terrestrial cellular stations? Or with Ericsson mobile test base stations? Considering the 300m altitude for the run, I wonder if this was done under more isolated test conditions, since they aren't likely to buzz an urban city.
I guess YMMV?
Comment
