From Hackaday:
The biggest issue with sending expensive electronics into near space is trying to recover them. [Lhiggs] set out to solve this issue with his Senior project for a Mechanical Engineering degree. He figured that a payload dropped from 100,000 feet should be able to glide its way back to some predefined coordinates. Here you can see one of the tests, where the payload is guiding its descent using a parafoil.
Directional control is possible with a parafoil simply by shifting weight between the two supporting ropes. In this case [Lhiggs] designed the payload to hang from a pair of servo-motor-actuated arms. Since the payload already carries altitude and position hardware (such as a GPS, electronic compass, and altimeter) it’s just a matter of waiting for the target height before separating from the weather balloon, then using the servos to navigate to the landing zone.
Unfortunately the project was never fully completed. But you can see that he got pretty far. There is test footage embedded after the break showing the device being dropped from a plane.
Comment by Daniel Nugent on October 3, 2012 at 10:14pm
Comment by Jack Crossfire on October 3, 2012 at 10:23pm If it didn't have to be completed, wonder what kind of senior project I could get away with.
There are quite a few guided parachutes out there, hats off to the chap for trying though http://www.atair.com/
Comment by Ed on October 4, 2012 at 7:24am @Daniel have a go, especially at high altitude as was the aim of this project. I think you'll be unpleasantly surprised by some of the dynamic effects you encounter, for example the added mass effect in low density fluids making it very unstable. It might make you less quick to dismiss it as easy.
Comment by Adrian Eves on October 4, 2012 at 9:14am I think low altitude dynamic effects and stability issues are the elephant in the room.... :)
I think Elephants by parachute is an excellent concept.
Comment by Kevin Brown on October 4, 2012 at 12:02pm Parachute and Parafoil are two different things.A parafoil was never designed to open like a chute....problem number one. Still like the idea.
I think I might chop up my X8 to look and operate like VG space ship II
any ideas on a rocket?
I saw the acrylic rocket on hackaday
Comment by Daniel Nugent on October 4, 2012 at 2:53pm You are correct the thing has to be in a free fall for a bit before it deploys its parachute so that it can be traveling at a high enough speed that the little air will have any effect on the parachute. Its more complicated than it sounds. I mostly just upset that I havent done it yet
Comment by MarcS on October 4, 2012 at 4:06pm The problem is already solved since years... Wings actually seems better than parachute.
It is just that no authoroty in the world allows for controlled recovery of radio-sonds (yet). At least on a regular basis...
One example here: http://www.gpsboomerang.com/content/view/21/34/
Comment by Ed on October 5, 2012 at 4:31am @ Daniel: no, that wasn't what I was talking about and that's not correct either. There is enough dynamic pressure up there for it to deploy, that is not a problem. Have a read up on the 'Added Mass effect' - Wikipedia is a good start.
@ Adrian, indeed if you cannot get it to work in the thick soup near sea level then you have larger problems.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
51 members
682 members
1288 members
182 members
Powered by
