we're working on two basic systems: flight control and autopilot
As to the system of flight control, we adopted the software from an open source project called MultiWii (http://multiwii.com). We made our IMU by soldering an accelerometer and a gyro, both of which can be cheaply available by tearing apart a Wii remote controller, onto an Arduino chip and used the IMU to build a quadrotor test bed for flight control software.
The above video shows how the flight control software was working on the test bed when we were debugging it.As you can see, we failed at the beginning where the test bed could barely take off. However, finally it was able to take off smoothly.
As to the system of autopilot, for our tracking system, we decided to adopt the algorithm from TLD which's inventive feature is the ability of real-time learning on the locked target so that it can update the latest samples for its detecting and recognizing. The following video shows its performance in tracking
Comment by Geoffrey Preston on October 15, 2012 at 6:31am Not exactly on topic but I do appreciate your artistic documentation.
Comment by Hex Air Robot on October 15, 2012 at 8:11pm Thanks, maybe I should try to work harder on the descriptions next time.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1290 members
87 members
10 members
110 members
182 members
Powered by
