  • Char of flitetest mentioned it in his Director Video as a KK2 Board
    But the processor core and hence math performance is exactly the same for a 328/2560, so we run into the same computational limitations when trying to make sense of the sensor data and calculate an AHRS solution. The performance gain from extra PWM hardware is marginal in this regard.
  • R_Lefebvre, No you got it backwards. The 328 on APM sums the PPM inputs into a format the Mega 2560 take tak ein in on one channel instead of reading 8channels with 8 pins thus limiting free resources on the 2560. Then, we smartly use the hardware timers within the 2560 which make PWM functions out for 8 or more channels of outputs to drive servos or speed controls. To say the 328 and 2560 have the same "power" is some serious over simplification. Bascially, they allow us to use the same IDE and more or less the same code base, but when we get into hardware performance, it's apples and oranges. See the chart below about PWM outs. 6 PWM outs on a 328P isn't going to cut it for an Octo.
    Arduino board models
    Processor
    Frequency
    Voltage
    Flash
    kB
    EEPROM
    kB
    SRAM
    kB
    Digital I/O
    pins
    ...with
    PWM
    Analog input
    pins
    ATmega1280
    16 MHz
    5 V
    128
    4
    8
    54
    14
    16
    ATmega2560
    16 MHz
    5 V
    256
    4
    8
    54
    14
    16
    ATmega328P
    16 MHz
    5 V
    32
    1
    2
    14
    6
    6
  • Which we then do through a 328 anyway... ;)
    @Lefebvre: Yes, that pretty much sums it up. The only thing that might make a difference is that the 1280/2560 has more hardware PWM channels, making it easier to drive servos/motors.
  • It would be really awesome if it came in purple.
    Ed
  • @John, really? I thought the 2560 had more power than a 328, 168, etc?  What does it have more of then? Just more IO and more RAM?
  • Thanks Dave.  That KK plus platform, sounds interesting.  Too bad it take some much hacking to get working.
    Also it answers the question Simon has about that that 5th input was:
  • I cant wait, Hobbyking I'm sure will keep this a reasonable price range which makes it even better.
  • @Ellison Someone has :) http://www.multircshop.com/site/index.php?route=information/informa...
    Multircshop.com
