    That poor EZ deserves a soft landing for once in it's life!
  • Admin
    Hi Earl , do you want to dump all of these at the same time ( probably in neighbor's backyard ;-) ) in single parachute drop ? The easystar had a tough life i guess. Are you looking for two stage release or some thing to bring them down from very high altitude balloon trip ?
    If you want to konw how to calculate it.. You simply use the drag equation where D = 1/2 rho v^2 S Cd
    D= Drag force, in case of parachute this will be the same as the of aircraft weight
    rho= air density which you can assume is 1.225 at sea level
    v^2= desired decent velocity
    S= parachute surface area
    Cd= drag coefficient of the parachute (this you cant realy find unless you have a wind tunnel or peform drop tests, however you can assume 0.75 for Cd
    Just solve the equation to find S
    Just make sure you test parachute with a similar weight before u test it on the aircraft cuz you are guessing the Cd so you will not destroy an aircraft cuz of a guessed value.
  • A drop of ALL of them at once. FROM A BIG BALLOON.
    36"
