Quick video of my newest bird, an Xaircraft X-650 V-8 featuring all new flight controller and AHRS V.2. I didn't realize I was in Acro mode in the beginning as seen in the video but figured it out eventually. Must have been some English/Chinese translation issue or maybe just the fact that I didn't read the manual :)
Anyway, enjoy the video
Comment by Ellison Chan on April 14, 2012 at 7:30pm Are you using all Xaircraft parts? Can you provide a parts list? Their flight controller seems to be all divided in to modules. There's a flight controller, which controls the motors, and a AHRS module for stabilization, and a separate compass module...
And what's this UltraPWM? Is it really compatible with standard RC equipment?
I purchased the basic kit with no extras. I plan on adding the new GPS Alt hold and RTH that they just came out with. All you need is a radio and battery and you're in the air. If you want heading or Alt hold, then you add the modules you want. You are correct that the unit comes with a Flight controller which is basically where all the in's and out's connect and then there is a "AHRS" or Altitude Heading Reference System module that plugs into the flight controller. The flight controller also supports 3 axis camera gimbals and additional modules.
Hope this helps.
Comment by Ellison Chan on April 14, 2012 at 7:41pm So where did you buy the kit from, Adam?
I have had the X-8 with V2 hardware for a little while also. Good quality and great performance for the price. The configuration software is very straight forward. The stabilized roll&tilt mount for a GoPro/compact camera also works very well, and has geared servos for really smooth movements. Just make sure you get V2 hardware. There seems to be a lot of problems with the first generation.
Highly recommended as a starting point for getting into areal photography and filming.
Comment
1283 members
676 members
4 members
8 members
Powered by
