Y650 Scorpion multi-rotor frame is a high quality glass fiber frame that offers both great looks and performance. Built from light weight yet extremely rigid glass fiber and aluminum, the Y650 offers a great combination of weight savings and strength.
The Y650s aggressive styling makes it look more like a deadly creature than a multi-rotor frame, while still offering excellent functionality and performance!
This multi-rotor frame is designed for use in the "Y-6" configuration utilizing 6 motors (3 mounted above and 3 mounted below).
Specifications:
Width: 650mm
Motor Bolt Holes: 32~40mm
Frame Weight: 410g (w/out electronics)
More information at Hobbyking: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=...
Comment by penpen on March 31, 2012 at 5:14am Great news !! This kit was sold around 150/250$ not so long ago. Thanks to HK to make more honest price !
Comment by John Stuart on March 31, 2012 at 6:21am Doesn't look too great from a camera mounting perspective - or is it just a fun frame?
Comment by Mike on March 31, 2012 at 11:48am It is available with a camera mount here http://www.infinity-hobby.com/main/index.php?cPath=239_237
I think these guys are the original designers. I bought a fair bit of kit from them and its all good...
Again same comment that I have around the X1/X525
great frames but you need to consider changing the motor mount in the short term. Carbon fiber plates are not good to use as mounts. They induce a lot of vibration as they are not stiff enough and they get stress fractures that will only get worst.
Get one of these, perfect match (but you lose the nice factor! sure you can keep the bottom portion... Might look ok)
For Canadians:
http://www.canadadrones.com/X1-X525-Aluminum-Motor-Mount-Set-p/x1-m...
For USA:
http://smallpartscnc.com/index.php?route=product/product&produc...
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
24 members
48 members
51 members
111 members
Powered by
