1080P 30X optical zoom camera with auto object tracking module
Hello guys,
Sky Eye-30HZ is a gimbal designed for 30X zoom camera for drone aerial inspection,surveillance,rescue and research mission,which can be easily installed on any multirotor platform.It consists of 1080P 30X optical zooming camera and a 3-axis high stabilized gimbal,which is able to take and record 1080P 30fps video to an on board TF card, giving you a stable eye in the sky that can be controlled via drone pilot or a secondary individual allowing for an overhead view that can cover a large amount of ground quickly and effectively. The 30X zoom function will allow you to remain at a distance yet zoom closely in on anything that requires your attention.
One big feature for Sky Eye-30HZ is that it can be equipped with an Auto Object Tracking Module(AOTM),which will enable the pilot to track moving objects very easily.
Sky Eye-30HZ provides an outstanding wiring hub design for RC receiver and video output port(AV and HDMI),which makes wiring pretty easily.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Sky Eye-30HZ has two video output ports,HDMI(1920*1080*60fps ) and Analog,which makes it possible to use traditional analog 5.8G video downlink or HD video downlink.The photo/video/playback functions can be chosen by a 3-gear switch on your radio.
Features
1)590grams,light weight
1)1/3 inch 3MP CMOS sensor
2)30X optical zoom,CVBS and 1080P/60 HDMI output for video downlink
3)1080P/30 H.264 video recorded for on-board TF card
4)Auto object tracking(Optional)
5)PWM control and serial command control
6)Convenient wiring hub for RC receiver and video output(AV and HDMI)
7)3-aixs high stabilized gimbal system
8)Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed for small zoom range,sensitive and quick.
Video
Please hit this link for more information:http://www.yangdaonline.com/sky-eye-30hz-1080p-30x-zoom-camera/
More photos
Auto object tracking module(AOTM) for Sky Eye-30HZ is released.
It is developed based on military grade tracking module,can easily capture and track moving object,makes the zoom camera an ideal tool for aerial inspection and surveillance.
Video footage
AOTM Photos
Do you have the Python tracking script available?
Sorry it does not have that.
Why do you need Python tracking script?Could you explain a little bit?
