I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
Are there any plans to add support for functions in Minimosd with KVTeam mod, would like to monitor my second battery I use for my gimbal.
You'll only hear a chorus of crickets after asking this question from the devs. Others will chime in they want it to.
I spent some time trying to get it to work, but haven't got it quite ready. I've been sidetracked way too often since i pledged my help with this.
i suppose what dissuaded me at the time is no one seemed able or willing to help me should i hit a wall.
in any case i have yet to exhaust all possibilities.
i will need this for myself going into spring. So its do or die in the next few months for me to finish this.
Please try the attached FW.
I did a very fast addition to normal battery voltage panel, just to see if it works.
After you have tested it we can step forwrd.
Gábor
Great, I'll try do do a test tomorrow after work. Thanks .-)
Need some help!  I received 2x RCTimer v2.0 MinimOSD modules and proceeded to follow the instructions Bjoern posted below.  "... just load the Character_Updater_FW.hex, update charset, and then update to plane or copter firmware thats in the same folder." My current problem is that I get "No Mav Data" showing on my display no matter what I flash.
I even swapped ports from Telem2 to Telem1 and cables but no improvement.  What am I doing wrong?
Hi, sorry for the late answer. I uloaded the new firmware but it still shows readings from the main battery, connected the gimbal battery to BAT2
What is it connected to, Pixhawk or APM?
Pixhawk
Most likely you havent set the correct parameters (https://code.google.com/p/minimosd-extra/wiki/APM), or its not connected right.
This is how I have it on all of 5 of mine
https://www.dropbox.com/s/52pspwp3zre4bsl/Apm%202.5%20connections%2...
Bjoern
im sorry forgot you had a pixhawk
http://copter.ardupilot.com/wiki/common-fpv-first-person-view/commo...
and i think these are the parameters i use on pixhawk, cant check for sure, im not home
SR1_RAW_SENS: 2
SR1_EXT_STAT: 2
SR1_RC_CHAN: 2
SR1_RAW_CTRL: 2
SR1_POSITION: 2
SR1_EXTRA1: 2
SR1_EXTRA2: 2
SR1_EXTRA3: 2
SR1_PARAMS: 0
SR2_RAW_SENS: 0
SR2_EXT_STAT: 2
SR2_RC_CHAN: 0
SR2_RAW_CTRL: 0
SR2_POSITION: 0
SR2_EXTRA1: 5
SR2_EXTRA2: 2
SR2_EXTRA3: 2
SR2_PARAMS: 0
Bjoern
I'm fairly certain on the Pixhawk there is no need to adjust the settings. I've never adjusted mine and the MinimOSD works fine. Of course, it won't hurt anything if you do change as recommended above.
well im not sure on that. I think the parameters are minimosd extra's thing. Something Gabor changed or something. On arducam osd they are not needed...
