I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
Would it be possible to add the mavlink error messages to MinimOSD extra?
Like Bad AHRS, Inconsistent Compass, gyro health, etc.  That's the only thing stopping me from flying without a computer.. I need a computer to tell me why I can't arm, occasionally.
Vote for this ;)
Is it possible to disable the flight summary page, or customise what is displayed?
Help ! I have APM 2.6 FW 3.2 Minim OSD 2.1.2.0 FW I have OSD wired as per instructions. power from APM tel port both LEDs on OSD lite (power to both sides)3rd LED flashing.  FPV video good but no OSD overlay. I have powered also via UBEC (OSD) with no luck. I do have 3DR and it works fine. Do I need to set APM par with 3.2 FW to get overlay ?
Hi, everybody, newbie here. Now I'm using MOE 2.4 r 727, on apm 2.7 and minim V1.1., it goes fine, only that doesn't show autotune, the others flight modes  are shown correctly. I'm trying to load R800, I have follow all the steps explained on the posts here, but I get nothing. I think it may be some parameter to change on apm. I have the recommended parameteres for plane (https://code.google.com/p/minimosd-extra/wiki/APM), or perhaps is a hardware requirement. Can any one post the hardware requirements and apm plane parameters needed to run R800 satisfactorily?. Thanks in advance.
I have a problem with changing characters
I OSD:
http://www.banggood.com/MinimOSD-MAVLink-OSD-APM-APM2-Flight-Contro...
controller APM2.6
I'm doing everything like this:
1. Begin EEPROM Erazem
2. Start with "OSD_Config.exe" from Firmware 2.2.0.0
3. In Table "Options" Click on "Update Firmware ..." and "Charater_Updater_FW.hex"
4. In tab "Options" Click on "Update charset ..." and "MinimOSD_2.4.0.2.mcm"
5. In tab "Options" Click on "Update Firmware ..." and "MinimOsd_Extra_Copter_R800.hex"
6. Set the date you wish to have.
The characters do not change ...
and leaves me with something like this:
Hi Marek,
Sorry to see that this is not working for you.
It did for me as I described in my previous report.
Just a wild guess though: Did you try NOT mounting the MinimOSD on your EMAX 4in1 and your video transmitter.
Maybe it's interfering the signals. Don't know only guessing.........
The charset is not uploading even tho it seems so.
Connect 12v to the camera side while uploading the charset only.
You dont need it for firmware to upload.
Bjoern
During the flight it is on ECS and video but does not affect the work.
I concluded a jumper as the web
When programming also powered from 12V or only with USB
Unfortunately unchanged.
Do you punch RESET At one point, when programmed?
Well, I get R800 to work, what I was missing was to power both sides, 5V and 12V, in order to upload firmware. Now, on the bench, I have R800 working, but still doesn't display Autotune flight mode, the others flight modes are shown correctly. BTW I have the Apm default parameters (not the MOE parameters https://code.google.com/p/minimosd-extra/wiki/APM ) and R800 is going fine, except the Autotune display, that doesn't change from Manual, but in MP displays Autotune when I change it.
I already changed Apm parameters, and it didn't change nothing. Autotune doesn't display on OSD but does it on MP.
About the reset button....
Do you see the prograssbar when updating?
If you dont have a full cable connected you need to press reset on both charset and
firmware upload. If you can upload firmware without pressing reset, you should be able to
update charset without too.
