I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
Already know how to do it. So no worries, knock yourself out.
Do you have any idea how to change the "BAUD" rate within MinimOSD?
Hi are there any  parameters i need to set in the pixhawk i getting no data to the osd
Did you try this in Missionplanner
it works fine under ArduCam V2.0
give it try Thank's
well that work
i like to know what it changed ?
take a look at  CONFIG/TUNING > Full Parameter list  > SRO_EXT_STAT up to SR3_RC_CHAN.
It is changed compaired to your previous settings.
"2" means it is set to automatic.
Using APM 2.6 FW 3.2 OSD extra Home direction arrow not working. I have set Par as
https://code.google.com/p/minimosd-extra/wiki/APM
Everything else seems to work. Any idea why ?
MinimOSD with APM
http://www.myrcflight.com/open-lrs.html
AlbEagle
Very good tutorial ! Thanks
Guys,
I am having a problem getting the minimOSD R800 Copter to work with Pixhawk running Copter 3.3
I do get the OSD. But the data is all 0 and frozen. ie nothing changes and remains as 0 .
I have the OSD connected to Telem 2 Port on Pixhawk Rechecked baud rate to 57
I have tried everything i could before posting here. please help !
