I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
minimosd-extras development is dead. Have a look at night_ghost minimOSD, which is where all the new stuff (and the cleaned up code) happens.
Hi Alexandre,
I got it working through Alceosd 0v3, the owner of this company was very helpful. I wrote a short blog on the freefly forums a bit of how to do it. For anybody who`s interested
http://forum.freeflysystems.com/index.php?threads/laser-altimeter.8...
Alexandre Cabrit said:
Hi Jason,
MinimOSD could not get the sonarrange values out of the MAVlink serial port. You need to modify the board to connect a Pin of the arduino cpu directly to the output of your lidar. Then add some lines of code in the arduino program to get this value and use it. But maybe arducam is more easy to modify than MinimOSD.
If you don't know how to do this... well keep on asking. You may find some very nice developers that may help you.. and me as well.
Jason Smoker said:
i know this a old thread but Im looking for sonar range? does it have it?
