Hey guys,
Is it possible for the Ardupilot to send telemetry updates over USB to a raspberry pi? I was able to did it using Ubuntu but for some reason it wouldn't send telemetry when I tried to connect the ardupilot with a raspberry pi.
Thanks in advance!
Did you ever figure out an answer to this?  Have the same issue and would love to know what you did
Yes, our problem was with the check-sum.  We were receiving the telemetry but the MAVLINK functions were dropping the data because we did not have the correct check-sum file.
Hope this helps
Would you be willing to share the code?  Would be a huge help
Wouldn't a direct serial connection be at least as good?
Hi Søren.
Yes this will work. Im currently using Rpi for video and telem.
Use Ser2net and just connect serial Tx/Rx Between APM and Rpi
Tommy L. uses his Rpi to stream telem and Video. :)
http://diydrones.com/video/my-mission-planner?xg_source=activity
